Weekend attempt at blocking heat - Defender Source
Old July 21st, 2013, 05:26 PM
Jbullis's Avatar
Jbullis
Jason Bullis
1994 NAS 90 #1810, 2006 LR3
I have spent this weekend dynamatting the floors, seat box, what I could get to of bulkhead. I have ran out and order another box to finish doors, rear wheel wells.
Has anybody used dynaliner with the dynamat to cut down heat. I have a box of the 1/2", and the 1/4". Gonna sample the 1/2" at the driver and passenger footboards. Put the 1/4" at the seat box and at the 2nd seat area.
Will update on how it works out.
Old July 21st, 2013, 07:45 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
I did that with my 110 but due to not wanting to stick anything to the sand glow paint I took the panels off and stuck it on the underside of them and bulkhead where I could reach. Transmission tunnel and bulkhead just behind exhaust down pipe (200tdi) got double layers. I used the Dynamat extreme. I had a huge improvement in blocking heat. Like from burning my feet with hiking boots on (190 ish degrees w IR gun) to flip flops and not feeling any heat. Seat box made a big different as well. I also "sealed" the panel seams with this stuff.
Blocking Cab Heat... Exmoor moulded matting? kinetic Defender Technical Discussions 5 December 29th, 2011 02:36 PM
Excessive heat in driver side foot well Chris Vitale Defender Technical Discussions 14 August 23rd, 2008 01:03 AM
Heat Sheild Bowtracer Defender Technical Discussions 14 July 7th, 2007 12:11 AM
strange heat issue jabber Defender Technical Discussions 15 March 6th, 2005 05:42 PM
Heat question Campbell Defender Technical Discussions 8 January 3rd, 2005 08:58 PM
