Webasto 300tdi Mounting Bracket - Defender Source
Old December 6th, 2013, 02:41 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
If anyone else is in the process, or considering a Webasto install on their 300tdi I have designed a mounting bracket for the Webasto to install in the location of the washer bottle right next to the heater. This is the ideal location for the Webasto. The idea is that you leave the washer bottle mount in place and bolt this bracket to the Webasto which then mates up with perfectly with the washer mount. The washer bottle will have to be replaced with a TD5 under wing style and moved to the other side of the bay. I will post pictures of the bracket once fabricated and I will post pics of the Webasto install in a separate thread.
Old December 18th, 2013, 06:51 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Webasto Adapter Bracket Design
Here the bracket adapter design to fit the Webasto in the 300tdi Washer Tank location. Final part arrives next week.
ID:	86364   Click image for larger version
Old January 2nd, 2014, 02:15 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Hey Carl, did you make any extras that you want to sell? I don't have a Webasto yet and it's pretty far back in line when it comes to projects (behind the York compressor, for sure) but if you're making a run of them, I'll take one.
edit: on second thought, I better make sure that I have this washer bracket. not so sure now...
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old January 2nd, 2014, 09:00 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
No problem. I'll have them make an extra one. Just let me know.
Old January 2nd, 2014, 09:44 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Carl:
I'd like a couple as well as I have 2 of the Webasto's that are not yet installed.
With the OM617. you can pretty much burn any type of fuel, so the plan will be to use it on our Mercedes powered 110 5 door wagon.
Want to work it out so the engine is completely warm before starting, start on diesel, and at the end of the driveway switch over to heated WVO or some other alternate fuel.
Also want to look at curculating the heated coolant through a flat plate HE that you can pump water through to have a hot shower. Currently we have to run the engine to heat the shower water.
Pictures of the unit mounted would be cool if you could post some once you have the install completed.
Thanks for sharing.
RDavisinVA
Old January 2nd, 2014, 01:29 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
No problem Robert. Brackets shocks be done in a week but I am still waiting for parts for the install so that might take a while longer. Will post full write up in separate thread.
Old January 2nd, 2014, 07:15 PM
chris snell
Chris Snell
87 Ex-MOD 110
Webasto-powered shower would be totally awesome. I'm not familiar with these heaters but I wonder if there is a way to turn down the heat output a bit. The problem with the motor-heated shower is that it's nice for a few minutes and then soon after you're burning the skin off your body when the water turns to steam.
2013 LR4
Old January 2nd, 2014, 09:13 PM
I have an onboard webasto powered water system that includes a coolant heat exchanger, water pressure pump and removable showerhead with mixer. when you use a mixer, you have cold water line and hot water line. the cold water line just bypasses the exchanger.
What I have learned is that you need the engine running to support a webasto shower. with engine off, the webasto electric circulation pump isn't strong enough to keep the flow going through the exchanger to keep the heat up. what the webasto will do is keep the coolant warm enough at idle so that the coolant can keep the water passing through the heat exchanger nice and hot. On a positive note, the webasto is perfect without engine running to provide warm water to do dishes and cleanup.
On a side note, I created my own mount for my webasto out of a few pieces of 1"aluminum bar stock from home depot. it's been rock solid for a few years now and I was able to mount my breather manifold and webasto relays to it as well.
Mark Kellgren
KM4BOR
Old January 2nd, 2014, 10:11 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Where is yours mounted, Mark?
Old January 2nd, 2014, 10:35 PM
RH wing between heater box and expansion tank, as high as I can fit to protect during wading
Mark Kellgren
KM4BOR
Old January 2nd, 2014, 11:27 PM
chris snell
Chris Snell
87 Ex-MOD 110
That's right where I want to put all of the OBA ancillaries like the manifold, filter, oiler, etc. The solution for me would be to relocate the washer bottle (it turns out that I do have the same bracket as Carl). Carl, did you manage to find all of the P/Ns needed to convert to the LH-wing Td5 bottle?
2013 LR4
Old January 3rd, 2014, 12:28 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I think so. Brian ordered them for me.
Old January 3rd, 2014, 08:26 AM
I replaced my windscreen fluid bottle with the version that conform under the LH wing behind the headlights. (PRC5777) which made room for the webasto.
Mark Kellgren
KM4BOR
Old January 3rd, 2014, 12:30 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I believe this is it.
Name:	Washer Bottle 2.jpg
Old February 11th, 2014, 04:19 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Brackets are done.
Can someone tell me what size mounting bolt the Webasto Thermotop C uses?
Old February 11th, 2014, 04:59 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Ejot screws
http://techwebasto.com/redirect/heat...t/5000778B.pdf.
Old February 11th, 2014, 05:05 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks. Do those come in different sizes?
Old February 11th, 2014, 06:58 PM
dang, missed this. I would totally go for one. Guess I don't spend enough time on here these days!
Old February 11th, 2014, 07:06 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Bracket? You may be in luck. I may have an extra one.
Old February 11th, 2014, 09:06 PM
yes.
I will take one if avail.
PM me with cost etc etc.
Thanks!
Dave
300tdi, ac, bracket, mount, rack, tdi, webasto
Gearbox Bracket ANR3225 for 300tdi, and Bulkhead Tunnel adapter RTC6826 Macker Wanted 1 December 20th, 2011 03:10 PM
Gearbox/Transfer Case Mounting Bracket Locations punter Defender Technical Discussions 7 December 17th, 2010 03:29 PM
Hella 4000 Mounting bracket ini88 Wanted 3 November 28th, 2007 11:55 PM
Stock tire Carrier Mounting Bracket Joe P Wanted 2 September 8th, 2005 08:11 PM
