Webasto 300tdi Mounting Bracket - Page 3 - Defender Source
Old September 18th, 2014, 08:41 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I think I have a couple more brackets left. I'll take a look. I'm not sure if that one fits. Mine is a Thermo Top C. I think there was a great bulk offer posted here somewhere but you'd have to get together and do a group purchase.
Old September 18th, 2014, 08:45 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Aren't they one in the same? TSL 17 and Thermotop C?
Old September 19th, 2014, 05:34 AM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Where did you find an under wing-mounted tank? Is this a special tank, or just a tank re-located?
Sorry I'm being so needy, trying to wrap up several projects before winter hits in New England.
Old September 19th, 2014, 08:52 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Not sure.
Old September 19th, 2014, 08:54 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
It's a special tank in that it's a TD5 tank do unless you have a TD5 you're going to have to order one. You will also need to order the pumps and wiring harness connectors.
Where did you find an under wing-mounted tank? Is this a special tank, or just a tank re-located? Sorry I'm being so needy, trying to wrap up several projects before winter hits in New England.
Old September 22nd, 2014, 03:33 PM
Greenbull's Avatar
Greenbull
Mark Miller
1994 Defender 90NAS #1258
I would be interested in knowing if anyone has wired the remote unit for the webasto into their fan unit in the cab, to pre-warm your vehicle. I have C top in my RRC and the remote, but haven't figured that one out yet. Have the on/off switch uner the hood for now, and last winter just turned it on manually to pre-heat...
Old September 22nd, 2014, 03:43 PM
I have. There is a signal that comes from the Webasto to turn the interior fan on when the coolant temperature is warm enough. This signal needs to control a relay that goes into the power feed to the fan. The normal switched power supply to the NC position and constant power to the NO position with the the output to the fan.
Old September 22nd, 2014, 04:03 PM
Greenbull's Avatar
Greenbull
Mark Miller
I am at work now, so not looking at the electrical schematic, but sounds like the signal device is wired into the fan's power supply?
Old September 24th, 2014, 01:36 PM
Greenbull's Avatar
Greenbull
Mark Miller
So you wired a defender or RRC?
Old September 24th, 2014, 02:14 PM
A defender but it has a different heater than stock. It should not matter. You need to tie into the power supply and understand the specific vehicle wiring in order to do it correctly.
If it is power switched like most you ned to et at the power feed before the switch. If it is ground switched like a defender you need to power supply to the motor.
Old September 24th, 2014, 02:16 PM
It is important to not only add power. You must break the power feed and run it through the relay. Otherwise you will back feed all of the other switched power items.
Old January 23rd, 2016, 12:30 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Reviving this thread
I got an inquiry about these brackets this week. I found 4 prototype brackets that I can sell at a discount. They're unfinished, a little thicker than the final version and the holes on the far left and right needs to be drilled out slightly to fit the washer bottle bracket bolts. $30 each, shipped. The final version sold for $40 each.
Old January 23rd, 2016, 01:40 PM
Greenbull's Avatar
Greenbull
Mark Miller
Carl,
Ill take one!
Old January 23rd, 2016, 01:42 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Great. I'll send you a Paypal invoice.
Old January 23rd, 2016, 02:47 PM
i'll take one too!
Mark Kellgren
KM4BOR
Old January 23rd, 2016, 02:57 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Invoice sent, Mark. Thanks!
2 left.
Here's a closer look. The center holes (for the Webasto) are in the right place but may have to be drilled out slightly. The holes that hold the bracket to the washer bottle bracket needs to move in about 2-3mm as per picture. You may be able to get away just filing them.
ID:	140151   Click image for larger version
Old January 23rd, 2016, 03:07 PM
Greenbull's Avatar
Greenbull
Mark Miller
are you pm ing that invoice? Ship both to Kellgren and we'll save the freight...
Old January 23rd, 2016, 03:12 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
You should have already received it.
I will put both in one package and send them to him.
Old January 23rd, 2016, 03:21 PM
Greenbull's Avatar
Greenbull
Mark Miller
or me either way.
greenbullnbear@gmail.com
Old January 23rd, 2016, 03:31 PM
yep. send mine to miller. thanks!
filing should be fine
------ Follow up post added January 23rd, 2016 03:31 PM ------
Now I need the water bottle bracket. Who has a used one?
Mark Kellgren
KM4BOR
300tdi, ac, bracket, mount, rack, tdi, webasto
Gearbox Bracket ANR3225 for 300tdi, and Bulkhead Tunnel adapter RTC6826 Macker Wanted 1 December 20th, 2011 03:10 PM
Gearbox/Transfer Case Mounting Bracket Locations punter Defender Technical Discussions 7 December 17th, 2010 03:29 PM
Hella 4000 Mounting bracket ini88 Wanted 3 November 28th, 2007 11:55 PM
Stock tire Carrier Mounting Bracket Joe P Wanted 2 September 8th, 2005 08:11 PM
