WD90's Build-Up - Defender Source
Old December 4th, 2013, 04:28 PM
WD90's Avatar
WD90
Dan
1995 NAS Defender 90
WD90's Build-Up
I've got a ton of projects going on with my Defender, so I'm going to start a build-up thread...
First project is replacing my mangled rear quarter panels (rear wings if you're in the UK):
Any advice or recommendations on this project will be greatly appreciated. I just ordered the parts from Safari HP!
Old December 4th, 2013, 05:02 PM
WD90's Avatar
WD90
Dan
Disregard the rusty bumper... I unbolted my cage from the rear bumper and I haven't cleaned it up yet...
Old December 4th, 2013, 07:03 PM
WD90's Avatar
WD90
Dan
With the amount of work it will take to redo, you will be money ahead to get a take off tub from the UK.
-Jeff
I ordered the RH/LH quarter panels today, as well as the corner cappings for each side and the rear panel behind the LR plate... I'll just have to spend the time drilling rivets. I spent less than $600 on the parts. The rear tub was going to be at least $1,500 plus shipping, which would have been quite expensive, I'm sure. I'll enjoy the labor, so it's all good.
Old December 4th, 2013, 07:19 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Did you get the tub quarters for both sides? Or did you just get the skins? If just the skins, what method are you going to use to attach them?
Old December 4th, 2013, 08:42 PM
WD90's Avatar
WD90
Dan
Take plenty of triangulated measurements before you start.
There are more spot welds than rivits. You will want to get a spot weld drill, clecos and cleco clamps.
Also might want to consider galvanizing the cappings while its apart, or at the very least, primed and painted on the back sides.
-Jeff
I bought the skins... Going to use a spot weld drill as suggested and rivet/glue method to reattach the panels. I'll definitely do my homework on the project. I was going to ask about galvanizing or painting the interior of the panels... I definitely want this to last.
Old December 4th, 2013, 09:41 PM
WD90's Avatar
WD90
Dan
It just dawned on me that I'll have to drill all of the rivet holes in the new panels... Clecos, check! There's a million forums talking about replacing panels, but I've yet to find good pictures or a possible video. I'll take photos of course, but my project is bound to be a trial/error...
Old December 5th, 2013, 01:34 PM
WD90's Avatar
WD90
Dan
I'm considering another color on my Defender since Coniston green shows off every spec of dirt. I don't care if it lowers the value since I plan on being buried in the thing.
We have a Corris Grey 2014 Sport with Dynamic package on the showroom that looks bad ass with all of the black trim... I'd like to use a grey like this...
I know I'll have to paint a few areas in the interior and under the hood, but I'm fine with it. I'll probably disassemble the thing as soon as I get moved into my next house.
Anyone good with photoshop? Curious to know what it would look like.
Old December 5th, 2013, 01:51 PM
jafir's Avatar
jafir
Jafir Elkurd
I've seen photos of defenders in Bonatti grey. I think they look great.
Old December 5th, 2013, 01:54 PM
Dan, do you think you have time/space to disassemble the body of the truck?
The reason I ask is because painting is more thorough that way.
I understand how you feel about changing a few body panels and wanting to change color. My truck started brown and after seeing that I needed to replace several front and rear panels, I decided to completely repaint.
Old December 5th, 2013, 02:01 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
-Jeff
Call Dave at Urban, see if he's got anything on the water or in stock
Old December 5th, 2013, 02:10 PM
WD90's Avatar
WD90
Dan
I just sold my house, so I'm looking for something to rent for a while that has a garage. As long as there's enough room to build a small paint booth, I'll be good. I'd rather paint the individual panels all at once.
I only needed the rear quarter/wing skins and the one rear panel on the back... they're already ordered and en route along with the one piece doors I bought from Dr. Aaron...
Old December 5th, 2013, 02:23 PM
WD90's Avatar
WD90
Dan
Not a fan of metallic on a defender. I like Nimbus grey, its a special edition Audi color.
For Land Rover colors, I like RAF blue. Keswick green is nice as well.
-Jeff
Aye, the metallic may show off every flaw in the panels... noted!
Nimbus grey is an awesome color! Thanks Jeff
Old January 17th, 2014, 02:57 PM
WD90's Avatar
WD90
Dan
I've installed my hardtop... huuuuugggeeee difference! I've had to actually turn my radio down a few times because it was too loud... and the heat works now!
Next thing on my plate is rebuilding my doors... can someone tell me where I can find replacement hardware for the window mechanisms? I want to replace pretty much all of the interior guts on my station wagon doors other than the glass itself... and I also need the window cranks.
Old January 17th, 2014, 04:48 PM
BlackField's Avatar
BlackField
Oscar
D110
Here are a few pics of my old Bonatti Grey 110:
Old January 21st, 2014, 08:05 PM
WD90's Avatar
WD90
Dan
Taillights have arrived!
Old January 22nd, 2014, 07:05 PM
WD90's Avatar
WD90
Dan
New LED taillights installed... I'm not terribly happy with the way they look, but it's much better than what I had.
Oh, and all those drips on the driveway are from a Nissan Pathfinder...
Old January 22nd, 2014, 07:12 PM
Wipac?
Old January 22nd, 2014, 07:18 PM
For an early door:
MTC8477 x 2
MUC3024
MUC3025
Old January 22nd, 2014, 07:19 PM
WD90's Avatar
WD90
Dan
Originally Posted by Rocky View Post
Wipac?
Yep, got em from Rovers North... I do like the more stock look of the other brands, but I already had these guys bought and shipped before I realized they were the Wipacs.
I forgot to add a pic of the 90 after I installed the hardtop, so here it is...
Old January 22nd, 2014, 07:22 PM
WD90's Avatar
WD90
Dan
I need to take those lamp guards off... they're getting kinda crusty...
90, d90
WTB D90 body parts - Considering a hybrid build. Roving Beetle Wanted 15 February 26th, 2010 12:19 PM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
Sway Bar Disco Build blkdiscoII Misc. Chit-Chat 1 March 6th, 2005 02:10 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
Rover Build - Rolling Chassis ?s Jase Misc. Chit-Chat 14 March 4th, 2004 10:32 AM
