Water pump gasket - Defender Source
Old August 5th, 2015, 11:11 PM
huibae's Avatar
huibae
Harold Lee
Jon Snow Badge 1122
Water pump gasket
So I got a new water pump for a 94 NAS D90 from Rovers North.
It came with two gaskets.
Ones more like paper and the other like rubber.
Which one should I use? Both?
ID:	126560   Click image for larger version
Old August 5th, 2015, 11:55 PM
mcoleman762's Avatar
mcoleman762
Mike Coleman
94 D90 ST/95 D90 SW/83 110
The black one with the blue sealant on it is the Genuine gasket. I'd use that. I tried an aftermarket one once, but noticed it was cut wrong as I was refitting the pump! I then bought a Genuine one, which fit perfect, and after a few years of use still seals without any leaks.
Grease on water pump gasket? peachyracer Defender Technical Discussions 6 February 12th, 2012 10:46 PM
Valley Gasket/Water Pump--Right Stuff or Hylomar? Grover Defender Technical Discussions 2 October 25th, 2008 05:38 PM
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
Water Pump Help!!! Dfndr90 Defender Technical Discussions 14 May 3rd, 2005 11:51 AM
Water pump replacement mwmcgehee Defender Technical Discussions 6 June 2nd, 2004 12:00 PM
