VNT Turbo install on 300tdi - Defender Source
Old January 29th, 2013, 04:03 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I thought I'd document my turbo upgrade for those who are interested. Last weekend I did a test fit of the new exhaust manifold in order to determine the location of the EGT sender. Since the old manifold is rusty I have decided to have exhaust manifold, turbo, exhaust tubes and possibly also the intake manifold ceramic coated. Not only does the coating precent rust but it also keeps the temperature higher inside the pipes and the overall temperature under the hood lower. Next up is to drill and tap the exhaust manifold then hand it in for coating. Once all the parts have been coated I'll post some photos of the final installation.
ID:	65436   Click image for larger version
ID:	65438   Click image for larger version
Old January 29th, 2013, 04:07 PM
is that your original intake or a replacement ?
Old January 29th, 2013, 04:10 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
The intake manifold pictured is original and I'm keeping it. The new (not rusty) exhaust manifold is the one that comes with the VNT kit.
Old January 29th, 2013, 06:46 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Where are you getting the ceramic coating done?
Old January 29th, 2013, 06:50 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
A place locally called Finish Line Coatings.
http://www.finishlinecoatings.com/
Old January 29th, 2013, 07:19 PM
higher pre-turbo exhaust temps is the complete opposite of what I would want.
Mark Kellgren
KM4BOR
Old January 29th, 2013, 07:40 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I guess we'll find out!
Old February 7th, 2013, 11:39 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
The Garrett GT-22 VNT Turbo back from getting ceramic coated.
Old February 7th, 2013, 01:09 PM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
That's pretty!
Old February 7th, 2013, 01:43 PM
Yudda's Avatar
Yudda
Rob
1997/300tdi/110
Looks good so far !
Old February 7th, 2013, 08:36 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Nice
Legend in My Own Mind.
Old February 18th, 2013, 11:27 AM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
How are you planning on controlling the vanes?
Old February 18th, 2013, 03:16 PM
Cube II's Avatar
Cube II
Michele
1997 D90
They will control themselves
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old February 18th, 2013, 06:20 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Magic?
Old February 20th, 2013, 11:43 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
They run off of a wastegate (type of thing) actuator.... at least the VGT on my Td5 does anyway.
Old February 23rd, 2013, 03:10 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
The Exhaust manifold has been ceramic coated and the EGT Sender installed.
ID:	66702   Click image for larger version
Old February 23rd, 2013, 03:53 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Very clean.
Michele
D90 VNTdi
[O]===[O]
Old March 3rd, 2013, 06:13 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Slow progress. I installed the turbo, exhaust and inlet manifold today. Here you can see why I was concerned about EGT Sender location. Not a lot of room. The instructions that come with the kit are not very detailed so there's a fair amount of guesswork and some parts need slight modifications to fit.
Question about priming the turbo. I tried shooting the oil from the syringe in the hole where the banjo bolt attach (top of turbo) but it doesn't go in. Does the oil drain hose need to be disconnected in order for the oil to flow in there? I just assumed the whole syringe would go in no problem but just a little bit got in before it overflowed.
ID:	67293   Click image for larger version
Old March 4th, 2013, 02:38 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
I know on some of the old military trucks I worked on (the Bedford MK) they suggested something like a pint or 2 to be "flushed" through the turbo prior to starting up from a rebuild.
Wha I would do, is try and pour as much as you can in via the top, then when you're ready to start, disconnect the solenoid on the FIP, and crank the engine over on the starter. for a good while too, until the oil light goes out. that way you know you'll have oil primed all around the main bearings and the rear of the engine.
By the time the engine fires up (when you reconnect the solenoid) there'll be plenty of oil in the turbo... just think how it drains overnight and then starts up "dry"(ish) in the morning.
Old March 4th, 2013, 10:38 PM
Turbofan's Avatar
Turbofan
Ethan
Originally Posted by diesel_jim View Post
What I would do, is try and pour as much as you can in via the top, then when you're ready to start, disconnect the solenoid on the FIP, and crank the engine over on the starter. for a good while too, until the oil light goes out. that way you know you'll have oil primed all around the main bearings and the rear of the engine.
x2 on this.
I was curious if you were going to build a more sophisticated setup for the turbo besides the stock actuator. These things can make some serious back pressure, like over 20psi between the turbo and exhaust manifo. I have one of these on my car, and after much experimenting, I have found I get more power with less pressure(using a pressure activated wastegate). Keep an eye on your EGT's since the back pressure will be so much more. If you haven't yet thought about it, it might be time to upgrade that anemic stock intercooler too!
300tdi, tdi
VNT Turbo kit for 300Tdi.....Worth it? jrose609 Defender Technical Discussions 40 August 17th, 2016 07:57 AM
DIY VNT turbo for 300TDI? jaherring Defender Technical Discussions 47 August 15th, 2013 07:26 PM
FS: good take-off 300Tdi turbo, manifold, and downpipe jrose609 For Sale - Parts 8 May 23rd, 2012 11:15 PM
300tdi exhaust and turbo. millerhlyf Wanted 2 March 29th, 2011 11:31 AM
