VNT Turbo install on 300tdi - Page 5 - Defender Source
Old March 28th, 2014, 12:26 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Chris, Take a deep breath and don't sell the kit. There's nothing to guarantee the Allard kit is any better. It's British craftsmanship. I was as frustrated as you are now when I first installed it. When spending a lot of cash on a kit you'd expect a bit more but I don't think we'll have to do much to get a great fit. I have a plan but I haven't had time to get anything fabbed up yet as I have a lot on my plate. We can reduce parts, make it look cleaner and it should avoid touching the alternator as well. Let's talk about my plan next time I'm up there. I can get the tubes bent here in P-town and I'll make custom silicone hoses if we can't find anything existing. Don't be bummed. You'll be very happy you did this.
Old March 28th, 2014, 04:10 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Mmh,
nothing really, on the same boat.
Stripped alternator without plastic cover, otherwise there's not enough room.
I tried to carefully position the hoses, I did the best I could.
That little stud is not touching the bend anymore, it did before though.
In the end, once everything is properly routed, it's okay, I never had a problem.
It's maybe not the best layout in the world, but at the time it was the best choice for me.
ID:	91953   Click image for larger version
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old March 28th, 2014, 06:51 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
The kit I sell is much better and a clean install. No modifications at all and bolts right up. It's available for 200tdi or 300tdi
Legend in My Own Mind.
Old March 28th, 2014, 06:56 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Old March 28th, 2014, 08:48 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Randy, do you have it in stock? Can you send me details?
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old March 28th, 2014, 08:50 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Who makes it and what kind of exhaust manifold is it?
Old March 28th, 2014, 09:09 AM
Cube II's Avatar
Cube II
Michele
1997 D90
What he said!
Originally Posted by Manimal View Post
Chris, Take a deep breath and don't sell the kit. There's nothing to guarantee the Allard kit is any better. It's British craftsmanship. (...)We can reduce parts, make it look cleaner and it should avoid touching the alternator as well. (...) get the tubes bent (...) make custom silicone hoses (...)
------ Follow up post added March 28th, 2014 02:10 PM ------
Nice!
Michele
D90 VNTdi
[O]===[O]
Old March 28th, 2014, 09:11 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Originally Posted by chris snell View Post
Randy, do you have it in stock? Can you send me details? Thanks
Sure Chris I will send info. I have none left in stock but they would be about 2 to 3 weeks away.
Manifold is a custom unit and it is an easy kit to install takes about 3 hrs and comes with every part needed.
Comes like this
Old March 28th, 2014, 09:14 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I will also put up info with pricing in the venders loft when I get home.
------ Follow up post added March 28th, 2014 09:15 AM ------
This along with an intercooler is an amazing power upgrade. There are a few guys here that I have set kits up for.
------ Follow up post added March 28th, 2014 09:18 AM ------
The nice thing is that everything is kept in stock location and no modifications to the hoses for turbo like other kits that make it look like a Home Depot plumbing job.
Old March 28th, 2014, 10:38 AM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
200tdi? Really? Is this an allisport kit?
Have you run a 200tdi kit? Or anyone else on here run one?
Old March 28th, 2014, 11:09 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Originally Posted by jrose609 View Post
200tdi? Really? Is this an allisport kit? Have you run a 200tdi kit? Or anyone else on here run one?
Yes, these are supplied to me through Allisport. And yes they have manifolds for the 200tdi as well. I have not ordered one yet though. So no pictures as of yet..
Old March 28th, 2014, 10:26 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
City drivability is night and day. Freeway remains the same.
I really wanted to hear about the change in driveability and no one has posted any real specifics. Carls truck has been apart so long he probably won't have much of a point of reference anymore.
Old March 29th, 2014, 07:14 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I can tell you that Bowie on the forum here has one on his 110. I installed it. Took a quick drive in it and noticed basically no turbo lag at all... Normally it takes a few seconds to get the 300 rpm up and then you hear the turbo spooling up. Once the turbo was installed, it kind of just pulls right from idle. I also installed a stock replacement Intercooler and adjusted the fueling for the upgrade.
Prior to installing the parts, the 110 was slow and had no pickup. After the upgrades I can say that the truck was much more fun to drive and pulled much harder.
He said it was a big improvement and enjoys the truck much more now.. Maybe he will see the thread and post so e feedback.
300tdi, tdi
VNT Turbo kit for 300Tdi.....Worth it? jrose609 Defender Technical Discussions 40 August 17th, 2016 07:57 AM
DIY VNT turbo for 300TDI? jaherring Defender Technical Discussions 47 August 15th, 2013 07:26 PM
FS: good take-off 300Tdi turbo, manifold, and downpipe jrose609 For Sale - Parts 8 May 23rd, 2012 11:15 PM
300tdi exhaust and turbo. millerhlyf Wanted 2 March 29th, 2011 11:31 AM
