VDO Gauge Parts/Installation/Problems Merged Threads - Page 8 - Defender Source
Old September 30th, 2010, 11:31 AM
Arjun
Arjun
Bumping for info/confirmation for 300TDI
Planning on switching over to VDO gauges at some point in the future, so I wanted to get confirmation on part numbers for a 300TDI before I start ordering them from egauges.com. I gathered all of the info here from different threads on the board, but wanted to confirmation on components where I've seen conflicting info.
Could the experts confirm/comments on the choices? Hopefully this will be useful to others in the future as well. Any and all help is great appreciated.
Water Temp Gauge
VDO Part Number: 310-105
Product Description: 2 1/16 250F Engine Temp. - Elec. Vision Black
Water Temp Sender
VDO Part Number: 323-095
Product Description: Temperature Sender: 250F/120C - 1/8-27 NPT -
Oil Temp Gauge
VDO Part Number: 310-106
Product Description: 2 1/16 300F Engine Temp. - Elec. Vision Black
Oil Temp Sender
VDO Part Number: 323-057
Product Description: Temperature Sender: 300F/150C - 1/8-27 NPT -
Oil Pressure Gauge
VDO Part Number: 350-104
Product Description: 2 1/16 80 PSI Engine Press. - Elec. Vision Black
Oil Pressure Sender
VDO Part Number: 360-009
Product Description: Pressure Sender: 0-80 PSI/5 Bar - 1/8-27 NPT - 7.0 PSI
QUESTION: Use 360-006 instead? I've seen both senders being mentioned.
Fuel Gauge
VDO Part Number: 301-105
Product Description: 2 1/16 for 240-33 Ohm sender Fuel level Vision Black
Fuel Gauge Sender
QUESTION: Can I use the stock 300TDI sender? If not, what should I use?
Speedometer
VDO Part Number: 437-155
Product Description: 4 120 MPH Speedometer Vision Black
Speedometer Sender
VDO Part Number: 340-011
Product Description: Speedometer Sender: Standard, GM - -
Tachometer
VDO Part Number: 333-158
Product Description: 2 1/16 6,000 RPM Tach - Electric Vision Black
QUESTION: Use 4000 RPM Tach (PN: 333-156) instead?
EGT Gauge
VDO Part Number: 310-153
Product Description: 2 1/16 250F-1650F Pyrometer / EGT Vision Black
Clock
VDO Part Number: 370-100B
Product Description: 2 1/16 Clock Vision Black
Old September 30th, 2010, 07:12 PM
Originally Posted by Arjun View Post
Fuel Gauge Sender
Speedometer
Speedometer Sender
Tachometer
Yes, stock sender works great on the fuel.
You need a VSS from either a Disco 1 or a TD5 Defender, not the 340-011 shown above. Used Disco 1 is the cheap, easy way...
I think 4000 rpm is fine.
Old September 30th, 2010, 09:32 PM
Arjun
Arjun
Thanks for the input. Any thoughts on the sender for the Oil Pressure Gauge? I found a bunch of references to Part Number 360-009, but then I saw a JimC post that says use 360-006 that has me confused.
Old September 30th, 2010, 10:42 PM
No idea. You need someone that has actually tried. It is more than the connection type, but the clearance as well. The pressure senders are quite large. I think if you read around on the UK forums, no stock VDO sender fits right on. Adapters are required.
Old September 30th, 2010, 11:46 PM
Mendicant
I'm not sure any more - egauges.com has change the part numbers for oil pressure senders and I don't have easy access to my RoverRecords to check what the distinction used to be...
Old October 1st, 2010, 08:07 AM
Arjun
Arjun
Thanks for chiming in JimC - I might as well get both senders and see which one fits.
Old November 4th, 2010, 08:17 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Water Temp Sender
What kind of funny electrical connector is that ?
- Charles Eames
Old November 4th, 2010, 09:42 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
A normal socketed (female) part of a crimp on blade connector will slide right on.
Chance
Old November 5th, 2010, 07:54 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Regular spade connector slides right over it.
Legend in My Own Mind.
Old November 5th, 2010, 05:05 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
thanks guys, there is always a first time
- Charles Eames
Old November 30th, 2010, 08:09 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
anyone noticed that the VDO voltmeter gauge is quite inaccurate ?
- Charles Eames
Old November 30th, 2010, 09:41 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I actually thought mine was doing pretty well. Maybe check your ground connection?
I installed mine on the accessory (2nd) battery of my dual battery setup and the gauge will read approximately 12V when the solenoid on the controller is not engaged and immediately jumps to approximately 14V when engaged
As a side note, I have noticed that my fuel gauge seems to bounce more than I expected but I have heard that is typically a sender issue, not a gauge issue
Old November 30th, 2010, 11:31 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
i have a good ground and a good positive, i checked it with a DMM, the thing is just inaccurate i guess. I'm trying to find a digital volmeter gauge that won't look too weird compare to VDO.
- Charles Eames
Old November 30th, 2010, 08:16 PM
There are some round digital ones. http://www.egauges.com/eg_typeI.asp?...r=All&Manf=All
If you do not need round, there are various choices for digital rectangular ones.
In my opinion, certain instruments should be digital. Voltmeters and EGT gauges are ones that should be digital. You want a precise number at a high part of the range.
Old December 13th, 2010, 12:09 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
How are the lights on the VDO Vision Black gauges that you installed. Brighter than stock?
Old December 13th, 2010, 01:00 AM
Many, many times brighter. The dials are through lit and the needles are lit as well. You need to dim the lighting or it is too bright.
Old December 13th, 2010, 09:28 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Well, that seals the deal for me. I'm replacing them. I was in the middle of swapping our the dash bulbs for LEDs when I got to the speedo cluster. LEDs are brighter for sure, I just don't like how the stock speedo, fuel gauge, temp,etc are backlit. They suck no matter what type of light source you have.
Are the VDOs LED? What color are they?
If I just swap out the stock dials do I need to swap out the senders for each?
When replacing the speedo, is it possible to calibrate it to have it read more accurate? Mine is about 12% off due to different gearing.
Old December 13th, 2010, 09:14 PM
The stock VDO lights are not LED, but you can get them. Stock bulbs are white. You can get whatever colours you want or use diffusers to change colour. Try them first. They are too bright without dimming...
http://www.egauges.com/vdo_agrp.asp?..._Bulbs_Sockets
Old December 15th, 2010, 07:33 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I know this has been covered. I just need some clarification. If I decide to swap out just the stock gauges and senders, is this the correct list of part numbers? Do I need a new tach sender? If so what part# is it? Where can I get a new VSS sender for the speedo? Am I missing anything on my list? Thanks in advance.
Water Temp Gauge $24.95 - VDO Part Number: 310-105
Water Temp Sender $6.50 - VDO Part Number: 323-095
Fuel Gauge $24.95 - VDO Part Number: 301-105
Fuel Gauge sender: Can I use existing 300tdi sender?
Speedometer $268.30 - VDO Part Number: 437-155
Speedo Sender: Where can I buy a new TD5 VSS sender?
Tachometer $74.95 - VDO Part Number: 333-156
Tach Sender? New or use existing? If new, what part#?
Old December 15th, 2010, 08:19 PM
Tach runs from the alternator. I would suggest picking up a laser non-contact tach to set it up. They are pretty cheap.
VSS part from any normal Rover parts supplier. Cheapest route is a used unit from a Disco 1. New ones are pricey.
Yes, existing fuel sender works well.
installation, part, parts, problems
Defender Returns to North America Merged Threadfest rover1 Misc. Chit-Chat 495 May 12th, 2010 10:32 AM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 09:20 PM
VDO Vision Series Fuel Gauge surf110 Defender Technical Discussions 4 September 13th, 2006 03:04 PM
VDO temp gauge sflash868 Defender Technical Discussions 3 May 31st, 2006 08:36 AM
vdo water gauge install and 210 fan info Davis Defender Technical Discussions 5 February 24th, 2005 10:47 PM
