VDO Gauge Parts/Installation/Problems Merged Threads - Page 6 - Defender Source
Old November 14th, 2008, 08:55 PM
Maybe a bad bulb or it is not in fully. They should all look identical.
Old November 15th, 2008, 08:59 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Good to hear they should all look identical. Hopefully the bulb is bad and I'll recheck the how it's sitting in there too. Thanks!
Old November 25th, 2008, 01:42 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Does anyone know which VDO oil temperature sender is needed for the 200TDI to plug in the 50-150C gauge?
Old August 30th, 2009, 08:16 PM
JSQ's Avatar
JSQ
Jack Quinlan
Has anyone installed a VDO programmable speedo in an early truck with a direct cable driven speedometer?
I don't run a VSS so I purchased the VDO adapter from E-gauges, but it's not looking like it's going play friendly. The square OEM cable is clipped into the tcase whereas the adapter threads on.
Thoughts?
Old August 30th, 2009, 08:45 PM
Thoughts?
Yes, it is explained somewhere around here. You need a sender from a Disco 1 or a TD5 Defender.
OK, read here: http://www.defendersource.com/forum/...ead.php?t=6703
The two pin Disco 1 sender is YBE100540, around $60 minimum.
The 3 pin TD5 Defender sender is YBE100530, around $35 minimum.
Note, I fitted the Disco sender with the small drive to an early box with the larger driven end and it works fine.
Old August 31st, 2009, 01:09 AM
JSQ's Avatar
JSQ
Jack Quinlan
By "sender" you're referring to a VSS for the later LT-230?
I'm not wild about that. VSS die pretty regularly. I was hoping to adapt the VDO hall effect sensor in lieu of adding a component that's fairly unreliable.
Then again, the speedo isn't essential and the VSS won't ruin my day the way it will in an ECU V8.
Old August 31st, 2009, 09:55 AM
No, the standard speedo sender that are used on Discovery 1s or the later ones used on TD5 Defenders. They plug into the transfer case. I've never heard of one dying.
The "VSS" as I understand it was a separate box on a cable for use by the ECU only.
Old August 31st, 2009, 01:09 PM
JSQ's Avatar
JSQ
Jack Quinlan
That's the Vehicle Speed Sensor.
All of the part numbers listed are the VSS.
They do die regularly. Check out discoweb. It just has few consequences on a truck where it's only sending signal to the speedometer. On the ECU V8 trucks the failure of the VSS interrupts engine power.
All said, I think I'll go the VSS route. The hall effect adapter I got from e-gauges looks two tricky to make work.
http://egauges.com/vdo_indS.asp?Send...ble&PN=340-011
Old August 31st, 2009, 03:39 PM
Well, I've had mine for quite a while now and it was off an old Disco so has had a long life..... There is nothing to the disco one. A spinning magnet and a proxy sensor in a plastic case. I had a quick look around DW and don't see anything to make me believe they fail any more than anything else.
The TD5 Defender ones are cheaper new and completely different. Find me a story of one failing.
Old September 4th, 2009, 11:23 AM
JSQ's Avatar
JSQ
Jack Quinlan
They newer YBE100530 and YBE100540 enjoy a better reputation.
I had a couple old used ones lying around, but I still don't trust them, so I picked up a new one. Hopefully wire it up today and see what happens.
Old September 9th, 2009, 06:06 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Are we sure that the oil pressure sender with 2 connections is four the gauge and the idiot light? Mine is marked with a G which I thought was ground, and the other has 2 letters that escape me at the moment, but that I figured was to the pressure gauge. But then again the warning light is pretty much named after me!
Old September 9th, 2009, 10:35 PM
What model sender did you purchase?
Old September 10th, 2009, 09:02 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
it looks just like the one in the pic at the beginning of this thread and it is a VDO
Old September 10th, 2009, 09:10 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Tom,
There isn't a ground wire. I believe it is grounded right to the engine. One wire is for the light, the other is for the gauge. At least, that is my understanding and that is how I have it set up.
Greg
Old September 10th, 2009, 09:34 AM
So you don't have a record of what you purchased?
Some senders have ground connections and some don't. VDO makes a huge number of different senders. You need to know what you have.....
http://www.sso-usa.com/performance/A...ure/index.html
Looks like only one has a ground connection. The first one I see referenced in this thread is 360-009 which uses the body for ground. Small connector will be the warning light and large the sender.
Old September 10th, 2009, 09:44 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Tom is not that organized!
Old September 10th, 2009, 10:06 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
You got that right!
Old September 10th, 2009, 11:19 AM
If I read this correctly... http://www.sso-usa.com/performance/A...ure/index.html
There should be markings on the sender which identify it.....
Old September 19th, 2009, 08:35 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
One post on my sender labeled G and the other says WK ?
Old September 20th, 2009, 06:16 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
G= gauge
WK = warning klight
It's like "knife", the "k" is silent.
installation, part, parts, problems
Defender Returns to North America Merged Threadfest rover1 Misc. Chit-Chat 495 May 12th, 2010 10:32 AM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 09:20 PM
VDO Vision Series Fuel Gauge surf110 Defender Technical Discussions 4 September 13th, 2006 03:04 PM
VDO temp gauge sflash868 Defender Technical Discussions 3 May 31st, 2006 08:36 AM
vdo water gauge install and 210 fan info Davis Defender Technical Discussions 5 February 24th, 2005 10:47 PM
