VDO Gauge Parts/Installation/Problems Merged Threads - Page 5 - Defender Source
Old February 13th, 2008, 11:07 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
i drove it around for a little and i noticed that when i turned on the headlights that the needle moved all the way over to the right. basically pegging to the right on the gauge.
also when i used the turn signal the needle would lightly move back and forth in time of the signal.
Old February 13th, 2008, 11:23 PM
Mendicant
Take the guage out, give it its very own ground (ground the other wire somewhere else) and reinstall. My VDO did exactly the same thing in the Tdi, but when I installed one in the V8 truck, I gave it a dedicated ground and it works perfectly.
Old February 14th, 2008, 08:17 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Mine too Jim... I also ran a ground strap from the t-case to the frame which solved all my gauge problems.
Legend in My Own Mind.
Old February 14th, 2008, 03:59 PM
airbornrover
William Skidmore
SIII 109 SW
ok, taken a closer look at what i did and what was going to the back of the old temp gauge. there was 3 ground wires going to the back of the old temp guage, 2 black wires were together (soldered together before) coming out of the harness so i just twist them together, crimped them as one and placed on the back of the new temp gauge. the 3rd one is coming off the back of the tachometers grounding point. so its basically a black wire extending from back of tach to the back of the temp gauge, there is another black wire coming out of the harness as well, which is going directly into the tach (assuming thats the ground for the tach?).
looked at both diagrams for the tach and the old temp gauge in the back of the workshop manual from what i can understand there is just one ground for the tach (ground symbol coming off the tach itself) and one ground for the temp at the point of the temp sensor (grounding symbol coming off the sensor).
when i disconnect this "extra" ground wire everything seemed to work fine?
let me know if i am missing something.
ps. been told i have a thing for absolutes.
Old February 25th, 2008, 06:01 PM
airbornrover
William Skidmore
SIII 109 SW
Angry Vdo Help Please
first, i appreicate all the help you guys have given me.
second, im still having problems with the vdo temp guage.
with that said. you can pick up the history on the other threads i have posted. to secure the gauge to the instrument panel i used the screw on "cup" that came with it which is made out of plastic. the green-blue wire is hooked up to the (S) spade on the back of the vdo with the green wire going into the positive connector. does seem to be a grounding issue. when i turn on the headllights it goes all the way to the right or with any switch it will move a little bit. even when im running a test ground wire to the bulkhead from the negative terminal on the guage. i was told before to ground the temp guage seperately so i figured one of the screws that run along the top behind the instrument panel. that did not work, i figured that its more plastic then metal so it didnt seem to ground.
the two black wires coming out of the wiring harness that connected to the old temp guage where do i ground those to?
the black wire that ran between the tach and the old temp guage where do i ground that to? or do i not have to worry about that anymore?
the fan clutch was replaced summer of last year. and the color and antifreeze tester show normal. radiator was replaced in late 04, early 05.
i do have the orginal factory repair manuel from 1994. so it does not have the complete circuit diagram like you do for the s3 and what have you.
thanks for any assistance.
Old February 25th, 2008, 07:29 PM
http://www.egauges.com/pdf/vdo/0-515-012-123.pdf
Switched +12 volts to the "+" connector
Ground to the "-" connector
Sensor wire to the "S" connector.
Not sure about NAS90s.... but on regular 90s, the green wire is the switched +12 volt. Ground is black. The sensor wire is Green with a blue stripe. This sounds like what you wrote.
What sender are you using? It must be a VDO sender. If it has only one connector, it grounds through the engine. When you put the sender in, did you put anything on the threads?
Old February 25th, 2008, 10:55 PM
airbornrover
William Skidmore
SIII 109 SW
nope, no plumbers tape or the like just bare metal to bare metal
Old March 10th, 2008, 07:44 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
I think the part number on the Oil Pressure Gauge should be #350-108. The part number you show is for the water temp guage.
And the adaptor is "5-1/8 F5OG-S" (the letter O, not the number zero)
Old March 10th, 2008, 07:49 AM
Mendicant
I find its easier to convert the old sender than to buy an adapter. I've just knocked out the guts of the stock sender and had a threaded bung welded onto it. That way you can get any size NPT sender you want.
Old March 10th, 2008, 07:56 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
That sounds much less expensive. It would be nice to have a "bung" welded somewhere on the truck too.
Old March 10th, 2008, 09:41 AM
Mendicant
I have at least one bung on each of my trucks. I try not to talk about it too loudly though...
Whoever came up with that name for a threaded chunk of metal really out to be hurt. The same with the person who appropriated the german word for "hose" into the english lexicon: schlong.
Old March 10th, 2008, 10:07 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
I just replaced about 8 inches of schlong this weekend. It was all dry-rotted.
Sorry, I should've left that one alone.
Old September 11th, 2008, 07:53 PM
I tried the two PN's for the temp sending units posted above. Have any of you had any trouble with the sending units? They may have sent the wrong part so I havent ruled that out. I wanted to ask before I start ordering more parts. Thanks.
Old September 12th, 2008, 07:50 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Mine are installed and appear to be working properly. What's you definition of "trouble"?
Old September 12th, 2008, 07:27 PM
I tried both of the ones posted in DJ's initial parts list and neither will work, they are too small. So I stuck the stocker sensor in but naturally the gauge isnt really correct.
Old September 12th, 2008, 07:47 PM
Mendicant
I had to use the 323-417 I think, IIRC my sender was the M16 size, not the M14.
Old September 13th, 2008, 06:48 AM
Thanks, I will try a couple of more. I havent had any luck with the local "speed shops" or parts houses. I hate to wait on egauges to ship. Thanks for your help.
Old September 27th, 2008, 09:25 AM
Ordered the 323-417 the M16 thread and it fit and everything works properly. Extremely nice and I am really glad I have a real temperature gauge. I did not change out the speedo but other wise everything looks great and the night time performance is far superior to the stock. Highly reccomend the VDO gauges.
Old September 27th, 2008, 11:18 AM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Originally Posted by DJ Menasco
Sorry about the delay, while I don't have any working pictures available (D90 is in the shop) I do have some of the installation. I have left a list of the part numbers for the VDO gauges below. As for swapping out the lights I guess you could do that but I'm not sure where to find a bulb that possesses a higher wattage nor am I aware of the listed wattage. Personally the VDO's are far superior and less expensive in the long run as any accessory or part is easy to find.
I purchased all of my senders and gauges from egauges.com. Also all of the gauges are VDO Vision Black Series and are 2 1/16 in diameter except for the Speedometer which is 4-in.
Electronic Speedo: 85MPH (#437 154), however these might be out of production by now so you'll have to use the 120MPH (#437 155)
Speedo Sender: GM Sender (#340 011)
Temp Gauge: 250F/150C Range (#310 105)
Temp Sender: 250F/150C Range (#323-417). This is for a late 95, 3.9L. The It should be M16x1.5 (#323 417).
Tachometer: 6K RPM (#333 158) Just use the same wire from your alternator.
Fuel Gauge: Vision (#301 105) Again just use the same wire from the sender in the tank. There is no need to swap that out.
Electrically the only modifications that you'll have to perform are to establish new connections for the programmable speedometer and exchange the OEM light sockets for the VDO sockets using the same wires. The other issue is the Speedo sensor. You can do it yourself or take it to a speedometer-shop and have them install it. I had a shop do it for about $50.
Ill post some of my install pictures later tonight.
Regards
DJ
Updated the sender info. with correct dimensions and VDO part number.
Old November 14th, 2008, 09:34 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Just wanted to say thanks to all that posted on this thread and especially to DJ Menasco for the complete writeup. I wouldn't have been able to figure out the install without it. Great description and pictures.
The VDO guages are very nice and worth the upgrade. The only problem I am having is the Tach light isn't as bright as the Temp and Fuel level. Tach does match the stock Speedo so it sorta balances it out but I wouldn't mind seeing the numbers better at night. For all I know it might just be the bulb. Add to the "bothers me but I have other crap to fix first list"
installation, part, parts, problems
Defender Returns to North America Merged Threadfest rover1 Misc. Chit-Chat 495 May 12th, 2010 10:32 AM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 09:20 PM
VDO Vision Series Fuel Gauge surf110 Defender Technical Discussions 4 September 13th, 2006 03:04 PM
VDO temp gauge sflash868 Defender Technical Discussions 3 May 31st, 2006 08:36 AM
vdo water gauge install and 210 fan info Davis Defender Technical Discussions 5 February 24th, 2005 10:47 PM
