VDO Gauge Parts/Installation/Problems Merged Threads - Page 17 - Defender Source
Old July 30th, 2016, 08:52 AM
Sand110
Steve Day
1988 110 County Station Wagon
This is what I'm getting at the tank.
Old July 30th, 2016, 08:57 AM
Originally Posted by Sand110 View Post
Thanks Red90, I purchased this model from Merlin Motorsport:
https://www.merlinmotorsport.co.uk/p...type-301010002
I did the wiring myself and is correct.
That is the wrong gauge. It is a VDO range (10 to 180 Ohm) one.
You need 301-105 with a 240-33 Ohm range.
Old July 30th, 2016, 04:02 PM
Sand110
Steve Day
Argh. So frustrating! Thank you!
Old July 30th, 2016, 04:27 PM
Sand110
Steve Day
I see, only available for purchase from the US. Will have to just take the hit on the shipping unless anyone knows a UK provider?
Old August 25th, 2016, 03:15 PM
RBBailey
RBBailey
1965 IIa
What do you all do with the extra length of EGT signal wire? I have no room to cool it behind dash anyplace.
Project:
1965 IIa SWB
Old August 25th, 2016, 03:21 PM
Coil it in the engine compartment.
Old August 25th, 2016, 03:26 PM
Umm, trim the wires to whatever length you want.
Old August 25th, 2016, 03:39 PM
RBBailey
RBBailey
1965 IIa
Instructions say not to clip wires.
Didn't feel like having it just coiled in the engine compartment, but I think I may have an option to put it over the wheel well, under the wing.
Project:
1965 IIa SWB
Old August 25th, 2016, 03:44 PM
What instructions? That is silly. There is nothing special with regard to lead length on a thermocouple. The biggest no-no is differing metals, but Madman does not seem to care as he is not using proper thermocouple wire.
Old August 25th, 2016, 04:14 PM
RBBailey
RBBailey
1965 IIa
Right... I have no clue. Not like I'm building a nuclear device here, or anything. But someone mentioned it to me that they had to replace their wires because they cut them, then I found this: https://www.google.com/url?sa=t&rct=...fTfc1IEba9f3Zw
First thing: DO NOT CUT SENDER WIRE !!
So call me baffled, but I'm just following instructions.
Project:
1965 IIa SWB
Old August 25th, 2016, 04:22 PM
I used an Auber EGT probe. Here is a quote from their instruction page:
"NOTE: Do NOT cut or splice the thermocouple lead wire as it is special wire that provides correct reading to the gauge. Simply coil any excess wire out of the way."
Old August 25th, 2016, 04:40 PM
It does not matter to trim the wires. You want avoid junctions with other metals as it creates a second thermocouple. With the Madman you have to do it as they do not include proper K type wire in their harness.
In a normal TC installation in industry you use wires and junctions that match the metal types used in the TC. Length of the wires has no impact on accuracy.
Old August 25th, 2016, 04:47 PM
RBBailey
RBBailey
1965 IIa
I was trying to figure it out, and I think they must just be trying to make sure people don't mess up the wires by putting junctions in it, or by using the junction they have (with the screws) improperly. Like trying to solder it together or something. Just telling people not to cut it at all covers all the bases.
Project:
1965 IIa SWB
Old August 25th, 2016, 05:23 PM
Maybe instead of solid TC lead wire they use a plated wire and cutting the ends gets away from the plated sections. Because we are measuring at a high temperature I doubt the ambient junctions impact accuracy enough to matter. Obviously Madman does not care as they use copper leads that require junctions.
Old August 25th, 2016, 05:32 PM
Naplm00
Matthew
I made the same mistake when installing my vdo egt. Since it came with no instructions I just started installing and clipped the long extension wire to size.
Frankly it didn't seem to make it not work. Maybe slightly less accurate but who really knows... Gauge works fine
Old August 25th, 2016, 05:34 PM
Reading a bit. It is okay for the copper lead junction, but both junction must be at the same temperature and should be close to the instrument so that the cold junction compensation within the instrument is at the same temperature as the extension lead junction with the dissimilar metals.
Old March 3rd, 2017, 02:48 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Anyone have an LED part number for the EGT and Tach gauge bulb. They aren't the bigger type E my other VDO's use. It seems to be a Type D peanut bulb. I want them in green.
600-822: Type D Wedge Based Peanut Bulb, red, 24V. 1.2W, 4 Pack , by VDO - eGauges.com
It looks like a 286 bulb I THINK but not positive?
EDIT
Called VDO they say it is a 73 style bulb. It appears this will work?
https://www.superbrightleds.com/more...Specifications
Old April 29th, 2017, 01:03 AM
cowboy
steven
'84 2-carb'd V8 4-speed 110 LHD SW
Can anyone tell me what type of resistor and where in the string of speedo replacement wiring the resistor would go that leastonce refers to in this post?:
http://www.defendersource.com/forum/...tml#post668175
Old April 29th, 2017, 08:27 AM
See here: http://www.defendersource.com/forum/...tml#post497139
It is only for using a YBE100540 with a 14CUX and VDO speedometer.
Old April 29th, 2017, 06:32 PM
cowboy
steven
Ok, the need for a resistor is not applicable to my rig, then. Thanks for that clarification, Red90!
But, otherwise, in theory, a model 437 158 VDO speedo* would work in my non-efi/non-ecu rig via the VDO wiring instructions for an "induction speed sensor" with either the YBE 100540 or YBE 100530 wired to the speedo & plugged into the port in the transfer case section of my LT-95 transmission?
And are we wiring directly into the YBE 100540/YBE 100530 or via a pigtail such as: Home » Shop » Connectors / Harnesses » Tyco / AMP » 3 - Way Econoseal J Series Plug Pigtail, Black ?
*https://www.vdo-instruments.com/inst...ation-12v.html
installation, part, parts, problems
Defender Returns to North America Merged Threadfest rover1 Misc. Chit-Chat 495 May 12th, 2010 10:32 AM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 09:20 PM
VDO Vision Series Fuel Gauge surf110 Defender Technical Discussions 4 September 13th, 2006 03:04 PM
VDO temp gauge sflash868 Defender Technical Discussions 3 May 31st, 2006 08:36 AM
vdo water gauge install and 210 fan info Davis Defender Technical Discussions 5 February 24th, 2005 10:47 PM
