VDO Gauge Parts/Installation/Problems Merged Threads - Page 15 - Defender Source
Old February 7th, 2016, 08:39 AM
1) You can use any gauge face that YOU WANT. They will all work. Which one you use is your own personal choice.
2) Speedo. Use any of the 4" speedos. In the Vision line, there are probably 5 different faces you can get. YOU decide which one YOU want. Then yes wire it up. You will want the connectors for both the speedo and the sender as well. Search and read. It has all been laid out on these forums.
3) Boost. The 150-1042 kit you showed includes the tubing and fittings. YOU need to drill and tap the plug on the manifold to fit.
4) Water temp. The 1/8" NPT sender goes directly into the engine. You do not need any adapter. Either kit listed will work and you throw the adapters in the garbage.
5) EGT. You have to drill and tap the EGR blanking plate for the fitting. Do a search. There are many writeups on the details.
Old February 11th, 2016, 11:40 AM
RBBailey
RBBailey
1965 IIa
Right, thanks for all the input. Once I realized I was misunderstanding your previous posts, it all made sense.
A few more questions:
  1. When looking at ammeters, I assume I want the 100amp range, since I'm running a 100amp alternator, correct?
  2. Some of them, like THIS ONE, say they do not require a shunt. Unsure if this might not work with the Rover?
  3. Buying one like THIS, am I going to be able to set it to make the warning light work?
  4. Will the fuel level instrument like THIS ONE allow the use of low fuel light with the stock Rover sender? I assume this is the 'warning contact'.
  5. What ohm range do I want for the fuel instrument?
Just so there is no confusion, I am using the vision black line, but thought it might be cool to have an onyx line cluster of Fuel, Amps, and Volts in the lower dash. But that's just me.
Project:
1965 IIa SWB
Old February 11th, 2016, 12:52 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Fit a volt meter instead, amp meters went out with generators. Plus no need to run large wires into the cabin.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old February 11th, 2016, 01:33 PM
Yes, a voltmeter is more useful as long as you understand what the numbers mean. A digital voltmeter is the best as small changes are important.
Old February 11th, 2016, 03:47 PM
RBBailey
RBBailey
1965 IIa
Had both in mind.
But! I hadn't considered the large wire issue. I'll looking out it.
What about the sender ohm rate for a 1988 petrol?
And the warning light option?
Project:
1965 IIa SWB
Old February 11th, 2016, 03:59 PM
You want the 301-105 gauge as previously stated and it will work with the the stock sender. The low fuel light has nothing to do with gauge.
Old February 17th, 2016, 04:10 PM
JSQ's Avatar
JSQ
Jack Quinlan
Originally Posted by Red90 View Post
The port where most people connect the boost gauge tubing has an M12x1.75 plug. Most people drill and tap the plug instead of trying to find the weird size.
Are you sure it's not M12x1.50? I just did this for the second time and both bolts I used to drill and tap were 1.50.
I wanted to leave the plug intact in case the drilling went badly so I got fresh bolts each time.
Old February 17th, 2016, 04:34 PM
You are probably right.
http://www.defendersource.com/forum/...old-54314.html
That would be good as adapters are not that hard to find....
R7962: Adapter Bushing - 1/8 NPT female x M12 X 1.5 male , by ISSPRO - eBuggies.com
Old February 18th, 2016, 12:00 PM
burlsube
Nick
1985 110 CSW
VDO Temp gauge tick marks
The tick marks on the 310-105 temp gauges are confusing. The marks are not equidistant and depending where on the sweep you are they may or may not carry the same weighting.
From what I can tell the temps that correspond the gauge are:
100-X-X-X-180-X-X-X-212-220-240-250
Can any one fill in the blanks?
Old February 19th, 2016, 11:34 PM
RBBailey
RBBailey
1965 IIa
If this is the case, should I order only the gauge, or get the kit just for the tubing?
This would be a lot easier with it in hand.... I kind of like to actually see things that I'm trying to work on....
Project:
1965 IIa SWB
Old February 20th, 2016, 05:16 AM
RBBailey
RBBailey
1965 IIa
This for 300Tdi?
350-1042: Vision Black Electrical Engine Pressure Gauge | VDO Gauges | eBuggies.com
Project:
1965 IIa SWB
Old February 20th, 2016, 12:27 PM
RBBailey
RBBailey
1965 IIa
Bump for these last two questions.
Project:
1965 IIa SWB
Old February 20th, 2016, 08:59 PM
RBBailey
RBBailey
1965 IIa
Bump. Want to push the order button asap.
Project:
1965 IIa SWB
Old February 20th, 2016, 09:20 PM
Yes, the electric 0-80 PSI gauge is what you need.
Old February 20th, 2016, 09:26 PM
RBBailey
RBBailey
1965 IIa
Thanks!
Project:
1965 IIa SWB
Old February 23rd, 2016, 04:25 PM
RhinoRover's Avatar
RhinoRover
Andy
1986 D110
'86 ROW 3.5 V8 to 4.2L RRC swap
I have read through the entire post and either missed the info I am seeking or didn't understand. Could some one please help me find the correct parts for my conversion?
I am nearing the end of transferring a 4.2L with the ZF auto tranny and corresponding transfer case into my 1986 RHD 110 originally powered with a 3.5 V8 and an LT95 tranny. I would like to keep the original speedo (for originality) and replace the oil and water gauges (they're not original). However, I have absolutely no problem with a new speedo. I see VDO is the way to go and I can have the original mileage loaded by VDO, but which speedo do I get, and how and to what do I connect it to? What parts will I need to source? The VSS is currently bolted to the chassis and connected. The truck currently runs great at idle, but I'm not ready to try it on the road because I'm waiting to get all the gauges connected.
Thanks in advance.
Old March 6th, 2016, 11:28 PM
RBBailey
RBBailey
1965 IIa
Originally Posted by RBBailey View Post
So, if have this gauge, but want a warning light to go on at a low or high point, is there a way to piggyback onto same sender, or is there another location on the engine that can take an automatic switch like that?
Also, same question for EGT and water temp.
Project:
1965 IIa SWB
Old March 7th, 2016, 01:02 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Ben, I wouldn't fret so much about the gauges. When I first dropped in the new motor, I was stressing out about monitoring everything on the motor, especially temperature--I had dealt with so many cooling system issues on the old truck. Jack alluded to this in a discussion we had on the EE BBS but it took experience with the three hundy to realize that they are generally really well-behaved. It's a challenge to get them up to temperature in the winter and they stay cool in the summer, even with the puny radiator. So long as you're not going wild on the IP tuning, you don't need a boost gauge. You can measure boost during the tuning process but you won't need a running display of it once you're on the road. The tachometer is even more unnecessary. You'll be an expert at driving your new motor by feel by the end of the first day. Shift quickly for better milage; let it rev a little higher when you want torque. You'll know when you've maxed it out before you get anywhere near redline.
As for the one important gauge (EGT), I did a write-up on the EE BBS if you have an account there:
Northwest by Ex-MOD - Page 2 - Expedition Exchange Bulletin Boards
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old March 7th, 2016, 07:49 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by ini88 View Post
To get your speedometer mileage put on for free. Mail your speedo to:
Continental
Attn. VDO Tech Support
6755 Snowdrift Road
Allentown, PA 18106
United States
800-265-1818
Send along a return address, phone number and miles needed on speedometer.
Just did this with my VDO. Was straight forward to do and they programmed the exact miles I told them to.
Old March 7th, 2016, 09:07 AM
93' NAS 110- #234
are they able to set the 97 style orm gauge and repair the lcd on it? what was the cost of svc they did for you?
Mark Kellgren
KM4BOR
installation, part, parts, problems
Defender Returns to North America Merged Threadfest rover1 Misc. Chit-Chat 495 May 12th, 2010 10:32 AM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 09:20 PM
VDO Vision Series Fuel Gauge surf110 Defender Technical Discussions 4 September 13th, 2006 03:04 PM
VDO temp gauge sflash868 Defender Technical Discussions 3 May 31st, 2006 08:36 AM
vdo water gauge install and 210 fan info Davis Defender Technical Discussions 5 February 24th, 2005 10:47 PM
