VDO Gauge Parts/Installation/Problems Merged Threads - Page 14 - Defender Source
Old January 17th, 2015, 03:37 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I looked at it but decided not to use it because it's easy enough to get the hall effect transducer to work properly. You just have to use good quality wiring, do a "home run" of wire straight from the transducer to the gauge, and take extra care to make sure your grounds are solid.
The GPS sender is expensive and may not work well in an urban setting or dense trees where the signal is good.
Here's the harness that I built for my VDO gauges, along with a drawing that I made to help sort out the wiring paths.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old January 17th, 2015, 05:29 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
I ran a separate ground for each gauge. I thought about piggybacking like that but just did for the - of the lights. All the stories of bogus readings and they are fixed with a separate ground got me to do it like that from the start.
Make sure you leave a "loop" or some extra length between the speedo and the next gauge. That dash support bar will interfere with the wires. I had to redo my harness because I couldnt get the dash all the way in because the wires were binding.
I used one Delphi weather pack for the ground and then another for the power and sender wires.
Old April 20th, 2015, 03:55 PM
I have a VDO 250F temp gauge for my 2.8 and the matching temp sensor, but the sensor has gone bad. I want to replace with a land rover sender for the 2.8 (same as 300 tdi) tstat housing hole. Does anyone know which LR sendor matches the VDO ohm range and fits in the 300 TDI housing? there's green and black 300 tdi sendors, but I don't know which one can be used, if any.
Mark Kellgren
KM4BOR
Old April 20th, 2015, 04:04 PM
You need to get a VDO sender, not a Land Rover sender. Land Rover uses a completely different gauge range.
AFAIK, the 300TDI uses a 1/8" NPT thread.
323-095: Temperature Sender: 250F/120C - 1/8-27 NPT - Spade - Single , by VDO - eGauges.com
Old December 16th, 2015, 04:41 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
To get your speedometer mileage put on for free. Mail your speedo to:
Continental
Attn. VDO Tech Support
6755 Snowdrift Road
Allentown, PA 18106
United States
800-265-1818
Send along a return address, phone number and miles needed on speedometer.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old December 16th, 2015, 05:36 PM
BlackField's Avatar
BlackField
Oscar
D110
I use it everyday with no issue. A little initial lag but then its fine, even in the city.
Old December 16th, 2015, 07:04 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by ini88 View Post
To get your speedometer mileage put on for free. Mail your speedo to: Continental Attn. VDO Tech Support 6755 Snowdrift Road Allentown, PA 18106 United States 800-265-1818 Send along a return address, phone number and miles needed on speedometer.
Nice!
Thanks for tip - will get mine done soon.
Old February 6th, 2016, 04:52 PM
RBBailey
RBBailey
1965 IIa
I've been browsing this thread for an hour or so, I still fail to see a good list of VDO vision gauges to use on the 300Tdi. Anyone have a post # for me to look at?
I have this feeling that my shopping cart at egauges is completely wrong.
Project:
1965 IIa SWB
Old February 6th, 2016, 05:56 PM
RBBailey
RBBailey
1965 IIa
Here is my list so far for a 300tdi conversion from 3.5V8:
  1. Speedo = 437-158; Sender = ?
  2. Boost = 150-1042 (metric); Sender = ?
  3. Water Temp = 310-1052 (metric); Sender = ?
  4. Tach = 333-156 (metric); Sender = ?
  5. Fuel = 301-105; Sender should be the stock 1988 sender?
  6. EGT = 310-153; Sender in kit, not sure if match for 300tdi
What other gauges do I need? I have a separate volt/amp gauge, but may also get a VDO volt gauge.
Can I get confirmation of the senders I need?
Can I get confirmation that these are the gauges that are compatible?
Thanks.
Project:
1965 IIa SWB
Old February 6th, 2016, 07:22 PM
As to what gauges to use and the ranges, that is really your choice, not ours.... If you want a different range or metric, get those... If you want other gauges, get those.
Speedo = 437-158, sure if that is the range you want...; Sender = YBE100530 (stock TD5 Defender sender)
Boost = 150-1042, sure; It does not use a sender. It is a mechanical gauge.
Water Temp = 310-1052, sure; That one includes a sender. 300TDI is 1/8" NPT
Tach = 333-156, sure; Sender = Uses the alternator
Fuel = 301-105, yes; Sender should be the stock 1988 sender? Yes
EGT = 310-153; Sender in kit, not sure if match for 300tdi. Sure, that will work. I personally think digital with high memory is better.
Old February 6th, 2016, 09:14 PM
RBBailey
RBBailey
1965 IIa
OK, I suspected as much with the gauges. Yeah, I think I selected the wrong range on the speedo, but I think the others are about right.
I also wanted to know if the metric or English option was the best. I selected metric.
Project:
1965 IIa SWB
Old February 6th, 2016, 09:23 PM
Originally Posted by RBBailey View Post
. I selected metric. Thanks,
Your part numbers are all imperial face gauges. Not metric.
Old February 6th, 2016, 11:32 PM
RBBailey
RBBailey
1965 IIa
I was referring to the sending units. But I'll have to look at what the difference is on the face.
Project:
1965 IIa SWB
Old February 6th, 2016, 11:41 PM
There is only one VDO sending unit mentioned above and it is 1/8" NPT which is not a metric thread.
Old February 6th, 2016, 11:47 PM
And I guess the EGT as well and that is 1/4" npt.
Old February 7th, 2016, 12:05 AM
RBBailey
RBBailey
1965 IIa
Well, I guess I'll start over.
Not sure what I'm looking for now though. I'll keep reading someplace.
Project:
1965 IIa SWB
Old February 7th, 2016, 12:17 AM
RBBailey
RBBailey
1965 IIa
I can't tell what the difference is between the two EGT gauges. (Other than the kit parts.)
Project:
1965 IIa SWB
Old February 7th, 2016, 12:49 AM
RBBailey
RBBailey
1965 IIa
OK, so other than the speedometer, which should be obvious, what is the difference between the metric versus English face? Which am I supposed to get?
For example, the boost gauge that I assume I need is the one that shows 0-30 PSI. They all say they are English, but one comes with no kit, another comes with an English kit, the third comes with the metric kit.
Which do I need, and why?
In the mean time, total blind guess. Is this the right speedo?
437-155 with SN16M
Project:
1965 IIa SWB
Old February 7th, 2016, 01:12 AM
You can use any 4" speedo you want. It is up to you which one you get. They are programmable and will work with any sender. The sender part number I gave above. It is the VSS for a TD5 Defender.
The port where most people connect the boost gauge tubing has an M12x1.75 plug. Most people drill and tap the plug instead of trying to find the weird size.
Old February 7th, 2016, 01:31 AM
RBBailey
RBBailey
1965 IIa
Oops... Sorry for the confusion. I just realized I was reading some of your posts in the wrong way.
I'm still not sure why the gauge faces I have chosen are wrong because they are Imperial. I was referring to the kits that come with the gauges as being US vs. Metric kits. I had assumed that metric kits would be what I would want for the Rover. But this is wrong? And it sounds like you are saying the Imperial gauge face may be incompatible with metric kits...?
Again, probably lost in translation there.
Then all I need is the right wiring to go from the transducer, correct?
I assume this is a tube of some kind? Size? Or just wait to measure when I get the truck here because it could be several?
So... is that the right kit, or do I want the English/US kit? 310-1051 also lists 1/8-27npt in the kit. I would think it might be better to just buy THIS, then wire it to the gauge (310-105). Or do these kits come with wires/connectors for the back of the gauge?
OK.
OK
I should wait to see/measure the threads on the truck then?
Project:
1965 IIa SWB
installation, part, parts, problems
Defender Returns to North America Merged Threadfest rover1 Misc. Chit-Chat 495 May 12th, 2010 11:32 AM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
VDO Vision Series Fuel Gauge surf110 Defender Technical Discussions 4 September 13th, 2006 04:04 PM
VDO temp gauge sflash868 Defender Technical Discussions 3 May 31st, 2006 09:36 AM
