VDO Gauge Parts/Installation/Problems Merged Threads - Page 13 - Defender Source
Old November 30th, 2011, 08:53 PM
carlosz's Avatar
carlosz
Carlos
all right guys here is my small contribution, I have just finished installing a vdo speedo in a customer's 97 d90.
the power up of the unit is described all over the forum, so is the conversion from mechanical to electronic speedo
on pre 96 "digital display odometer" trucks.
discission about the installation on 96 and 97 trucks however is very vague so I decided to make notes on my experience and here they are, if I can I will post a picture.
for starters, the factory plug at the back of the factory unit is a straight fit into the VDO unit.
the wire position do not match the location required by VDO in its instructions.
on the factory plug.
position # 1 is red with white tracer, this is lighted power (lights on/off)
position # 2 is white with green tracer, this is switched power (key on/off)
position # 3 is black this is ground
position # 4 is black with red tracer, this is the speedo PULSE signal (7 pulses per one wheel revolution)
position # 5 is black this is ground
position # 6 is empty, thus not used
position # 7 is yellow with pink tracer this is engine rpm signal to abs ecu, not used
position # 8 is empty.
on the VDO unit,
position # 8 is the speedo pulse signal input, black with red from factory position 4
position # 4 is the main power, it uses the white and green tracer from factory position 2
position # 7 is the main ground, it used any ground from factory position 6 or 3
position # 3 is the signal ground, with out this the speedo gauge will tend to act erratically. I did a "y" split for a set of grounds as factory provides 2 VDO needs 3, one for the lights.
the lights were wired in tandem and since they are fully insulated the power and ground can be reversed.
once all was installed, the VDO speedo would not register mph and I traveled a mile for it to register 1/10 of a mile.
a call to Egauges.com tech line solved the issue partially by suggesting the "calibration procedure" .
this issue was solved by using a gps to track a measured mile.
the truck was equipped with 4 brand new bf goodrich 265/75/16, the VDO unit provides a total count of pulses per mile... it turned out to be 8510 pulses per mile.
once it registered auto calibration, the speedo gauge begun to read and so did the odometer, within the gps readings.
BTW the factory speedo was replaced because it died, the odo stopped displaying.
I made short jumper wires in order to route signals as needed, and keeping the capacity of returning the truck to use the factory speedo if so desired in the future.
picture is last, showing back of unit with jumper wires ready for installation.
------ Follow up post added November 30th, 2011 09:03 PM ------
Old December 1st, 2011, 03:23 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Hey,
I couldn't find the thread anymore so I didn't reply immediately,
but thanks for the explanation, in the meanwhile I did figure it out on my own
Soo I replaced the sender, it fitted ok, same thread, and a mate helped me rewiring the gauge.
It worked ok until a couple of days ago when I disconnected the gauge for refitting the light bulb,
and now it doesn't work anymore...I checked the diagram and wires should be in the right position...
Well we'll fix it again.
Next it are oil pressure and temp gauges, I bought a brass adaptor/fitting but I realized it only has two ports, so I couldn't refit the stock sender...ouff..................................... ............
There's always something...
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old February 3rd, 2013, 07:52 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I've searched all am
Anyone have a part number on the VDO Vision EGT gauge and sender setup?
My manifold is off and it seems like a good time to set it up. Its a 200tdi.
Old February 3rd, 2013, 11:00 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
VDO 310-153. I don't know about the 200Tdi, I used the EGR blanker plate on my 300Tdi to mount the probe.
If the 200Tdi doesn't have a similar spot, you will need to somehow drill and tap a hole in your exhaust manifold before the turbo for the probe.
http://www.egauges.com/vdo_ind.asp?T...ion&PN=310-153
Old February 4th, 2013, 05:41 PM
JSQ's Avatar
JSQ
Jack Quinlan
My VDO speedo still has a mind of it's effing own.
That is all.
Old February 6th, 2013, 12:54 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
That is all.
Same here.
I farted around with it a while ago and took the dash apart and unplugged the the sender fromt the speedo cable. Cable was spinning smoothly down the road so who knows.
Not sure what to do might try to mess with it once I catch up with all my other projects on the 90.
Old February 9th, 2013, 12:23 AM
crobinson
Chris Robinson
97' D1
Question on the oil pressure guage.
Why is everyone going with a electronic operated guage w/sender instead of the mechanical guage? Is it the worry of a line rupturing?
Old February 9th, 2013, 08:37 AM
NADA
maybe hot oil in the cab?? Blows off the gauge and all over the cab if it fails?
Old February 9th, 2013, 10:03 AM
navydevildoc
Neill Thornton
Which is what exactly happened in my series, which has a mechanical gauge.
If electronic senders are good enough for the space shuttle, it's good enough for my rover.
Old February 9th, 2013, 11:37 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
It can also rupture under the hood and spray hot flammable oil on everything.
Old March 5th, 2013, 08:32 AM
d90dang's Avatar
d90dang
Matthew
1997 D-90
Looking to install a VDO boost gauge in my 300tdi would these be appropriate for the install?
http://egauges.com/vdo_ind.asp?Type=...ion&PN=150-104
http://egauges.com/vdo_indA.asp?PN=R7111
Old March 5th, 2013, 09:42 AM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
I use this one: http://egauges.com/vdo_ind.asp?Type=...on&PN=150-1212
Proud member of the YCHJCYA2PDTHFH club.
My mechanic told me, "I couldn't repair your brakes, so I made your horn louder."
Old March 5th, 2013, 10:48 AM
Yes, the 0-30 psi one is the best choice. There is no point in the vacuum/boost one as there is no vacuum...
The vacuum tubing kit won't work though... You need boost tubing that can take 30 psi.
Old March 9th, 2013, 12:12 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I'm sure I missed it somewhere in here, I'm pretty sure I've seen it listed before, but I am about to order all new gauges and I just want to double check. Which VDO Oil Pressure Guage and Sender should I get? I am running a 4.5l JE Engineering V8, which should be the same as a stock 3.9l in terms of the oil pressure port, but I don't know what thread I need for it.
I was thinking of just ordering one of the kits from egauges (350-1041 or 350-1042), but I don't know if I should order the Metric or US Kit...I feel like a dumb-ass right now, but I just want to make sure I get the right one the first time around if possible.
Thanks in advance!
Old April 10th, 2013, 09:44 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
The sender is in and I am getting ready to wire up my EGT gauge. Where is the best place to draw power and fuse the sender/gauge? Should I do an inline fuse or hook it up to the stock fuse box? Where is the best place to get power?
Old October 25th, 2013, 11:15 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Ok, I'm getting ready to order all New Vision Instruments for my NAS 110. I am trying to determine which Oil Pressure Gauge I need. The NAS 110 came with one from the factory, is there a VDO Gauge I can get that will work with the factory sender? If not, does anyone know the thread of the port on the housing for the sender so I can order the right sender and/or adapter?
Old December 17th, 2013, 07:15 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Oil pressure sender
Two references of oil pressure senders are mentioned in the thread:
360-006 and 360-009
They are the same part, same specs, the difference is the mounting thread.
360-006 is metric and has a 10 mm x 1.0 mm thread.
360-009 is imperial and has a 1/8" - 27 NPT thread.
Cheers
- Charles Eames
Old December 17th, 2013, 07:54 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Well I should have ordered the -006 then for my 200tdi. The -009 has worked so far along with a brass elbow to clear the housing.
Old July 7th, 2014, 02:37 PM
Chris B
72 + D1 drivetrain =?
How many wires come out of the VDO speed sensor? I'm trying to connect up a programmable Autometer....and struggling with the signal.
Old January 17th, 2015, 03:31 PM
BlackField's Avatar
BlackField
Oscar
D110
Anyone try using the VDO GPS sender?
http://www.usa.vdo.com/generator/www..._CO1482_E.html
installation, part, parts, problems
Defender Returns to North America Merged Threadfest rover1 Misc. Chit-Chat 495 May 12th, 2010 11:32 AM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
VDO Vision Series Fuel Gauge surf110 Defender Technical Discussions 4 September 13th, 2006 04:04 PM
VDO temp gauge sflash868 Defender Technical Discussions 3 May 31st, 2006 09:36 AM
