Tuffy Install: need to confirm drilling holes - Defender Source
Old January 21st, 2015, 05:26 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
So am slowly repairing the D-90 and purchased a Tuffy center con. I hate to drill holes in the truck but that is what the instruction say to do.Need to drill 4 5/16 inch holes?
All those with Tuffy's - is that the case? Leads to the second question, how the hell do you see/work around the trannie.
Tell me there is something I am missing and this is really simple.
I'm contemplating thinking about thinking about it!
Old January 21st, 2015, 06:14 PM
Willh's Avatar
Willh
Will Hedrick
Use to own NAS #96, #1778, & #1008
With the Tuffy's that I've installed, I actually re-drilled the Tuffy rather than the Rover to accommodate the Defender's existing cubby box mounts. It takes some measuring, but it saves having to drill holes in the 90!
Please feel free to visit my website at:
Willh is the F'n man! Defender of the Defenders! - Overlander
Old January 21st, 2015, 06:20 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Shim with wood to insulate it from heat.
Old January 21st, 2015, 08:52 PM
I drilled holes in the tuffy, I added some wood at the front. Its basically attaching to the transmission tunnel coveR,probably not the best.
Old January 21st, 2015, 09:45 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
Let me know how this turns out for you and please post what you did (and pictures) as I have plans for the same instal and rather dreading it.
Old January 22nd, 2015, 04:28 PM
paulb's Avatar
paulb
Paul / Boultbee
This is the project for the weekend. I will post pix.
Must say, for all the hype on Tuffy stuff, if you order from Tuffy the D90 Tuffy box I expect it to have predrilled holes.
Anyways, I plan to use the transmission cover holes to secure it.
More on Monday...
Old January 22nd, 2015, 05:31 PM
the tuffy is for many applications my only suggestion is to test fit a few times, i opted to keep the front cupholder, doing this did not put the little elbox pad far enoigh forward for me to rest on it while changing gears. i like having the cupholder on the front, i gained a little space in the back of my sw with the tuffy box its a really nice addtion
Old January 22nd, 2015, 09:29 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
At a little loss....
ok. I went the opposite way and removed a Tuffy (thanks javalinadave) and replaced it with a stock cubby...my issue was that someone had drilled new holes into the transmission cover and about 2 inches behind it to accommodate the Tuffy drillholes.
That's nuts..there is so much room underneath the center cover it's crazy. I'm all for redrilling the Tuffy to accommodate the cover. I was lucky enough that the beautiful person from this Board that supplied the cubby also sent the original center cover. Now I'm having the 2 small holes from the Tuffy repaired. Don't worry about clearance underneath. More than enough room.
Also, and I'm a stickler for stock, but I found the cold steel and angle"ness" of the Tuffys to be uninspiring and not pleasant..
FWIW....
KCD
Attributed to Shayne...
Drilling rear pinion...ok? sonoronos Defender Technical Discussions 16 February 4th, 2012 03:49 PM
Prefered method for drilling holes in the body cabell Defender Technical Discussions 8 November 4th, 2010 11:00 PM
Drilling out rivets aosias Defender Technical Discussions 9 March 12th, 2010 06:49 PM
re-drilling the swivel balls slorocco Truck Build-up's & Restores 15 November 17th, 2008 11:44 AM
Drilling holes for rear light guards khatadin Defender Technical Discussions 8 January 5th, 2005 08:43 PM
