Tub/Bumper/Jumpseat Redo - Page 2 - Defender Source
Old February 23rd, 2010, 06:28 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by evilfij View Post
Nice work Don.
Thanks Ron : And thanks for the deal on the seats. It makes the 90 more workable for me from bringing stuff to the recycling, to having the dog jump up through the back door, to carting a kid or 3 to a local indoor soccer game. The tip with the rubber layer was good too - it made sense once you mentioned it.
Old February 23rd, 2010, 07:14 PM
Looks great! Got any better shots of how you did the seatbelts?
Old February 23rd, 2010, 07:51 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks Charles!
I took these pics before I got the brackets powder'd and was test fitting:
http://bankbikes.com/D90/Tub_Project...ackets_raw.jpg
http://bankbikes.com/D90/Tub_Project...t_brackets.jpg
The male/seatbelt roll is mounted on the side of the angle brackets. It's a tight fit in the middle of the seats. Once I pull the top off in the spring I can maybe get an overhead shot. Hope that helps for now.
Old February 24th, 2010, 09:13 AM
Awesome job.
Old September 17th, 2010, 11:43 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
About a year after I started this project I'm still messing around... The lapbelts didn't seem right when the kids were in the back. After searching online forever I went with Corbeau's 2" harness belt in the 3 point configuration: http://corbeau.com/products/harness_...harness_belts/
After all the work I did making the lap belt brackets - I started over to make them fit and look right. I used the same type of angle iron for where the lap parts bolt in and then a piece of iron stock that goes across all points. The shoulder part was t-bolted to the iron stock and then wrapped around it to take up a bunch of material.
http://d90.unionstreetbikes.com/medi...picture&id=127
http://d90.unionstreetbikes.com/medi...picture&id=128
http://d90.unionstreetbikes.com/medi...picture&id=129
http://d90.unionstreetbikes.com/medi...picture&id=130
(Click on the pics for a full res version of it.)
I've gotten 2 done and they seem to be working well. The kids don't mind being snugged in and they think it's like going on one of the rides at the amusement park.
My 2nd update goes with storage. I took out one of the jumpseats and was looking for a storage box that fit. Troy didn't have any of his jumpseat boxes in stock and graciously offered to get a couple done but the cost was pricey (understandably so for a low quantity run).
I like my Tuffy center console so the fenderwell pair looked like it could fit with some modification: http://www.tuffyproducts.com/p-91-02...ckbox-set.aspx
I ordered it from Quadratec and when it came it looked a little different from the pic. Not a big deal and after messing around with it, I found I could stuff it into the area at the rear most of the tub under the lip and it would clear the jumpseat and bracket. The only thing is the lid wouldn't be able to open. So I cut about an inch off the back of the lid but left the hinge all the way intack. Got it as flush as I could and drilled holes for the 3rd brake light and for the speaker wires to come up. I also drilled 2 holes so the hinge bolts could hold the box from the back. And another to share the bolt with the spare tire carrier. I used some washers to space it off the rivit heads. Overall a pain in that I had that box in and out about 5x to get everything lined up but I'm pretty stoked at how it came out. As a bonus I can throw some 6x9 joints in the back now for some thumping sound (just need to fab a left side speaker holder :
http://d90.unionstreetbikes.com/medi...picture&id=132
http://d90.unionstreetbikes.com/medi...picture&id=141
http://d90.unionstreetbikes.com/medi...picture&id=143
The lighting is for sh!t but there are a bunch of pics on my site. I'll grab some more when everything is completely done back there - yea right...
Now - I just have to fab the brackets for the right side jump seat harness belts and make a speaker box for the left side.
P.S. - I have the left side Tuffy Box for sale if anyone wants it for there tub. Will bolt right in on a bench setup or follow the pics to instal with jumpseats.
Holler with any questions or comments.
Old September 18th, 2010, 10:52 AM
jaygoss's Avatar
jaygoss
Jay Goss
'60 Series II Station Wagon
is anyone else having trouble accessing the pics? Getting "404 error" message
1960 Series II 88" SW
1994 D90 ST Arles Blue (sold)
1963 SIIa SWB (sold)
1971 SIIa SWB (sold)
2000 Disco SII (sold)
1995 RR Classic SWB TWR edition (sold)
Old September 18th, 2010, 11:10 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Jay the earlier pics I moved to a new site. I'd go in and change the links but I can't edit old post.
You should be able to see the pics on the new site: http://d90.unionstreetbikes.com/media/index.php
Please let me know if you are having issues. Thanks
bumper
Redo heads or not? mlw911 Defender Technical Discussions 14 October 21st, 2004 02:42 PM
Cage Redo TDI Guy Defender Technical Discussions 3 April 15th, 2004 05:05 PM
