Transmission adapter - Defender Source
Old December 7th, 2014, 06:08 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Well, I wrode about it here: http://www.defendersource.com/forum/showpost.php?p=549709&postcount=20
Was a little bit mad about remouving it from the transbox to the gearbox. This makes no sence because you get lost about the correct angle.
So I made a new designed one:
matching the boxlifter's rod
clamping by nuts (the studs can be exchanged after a while)
axles are fixed against spinning
bracket got more strength
please have look:
separated parts and welded groups
mounted to the box in remouval/entering position
90 towards the pistonrod
I'll try to get it manufactured in about 10 hours.
That causes 250/each.
In fact there's anyone who will need it, please send me a PM and tell me about the outer diameter about his boxlifter!
kind regards
Kurt
Old December 7th, 2014, 07:19 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Kurt:
That is a fine piece of craftsmanship...
What is underneath as you don't see it in the pictures?
Is the very lower part a round mount for your transmission jack tube on a hydraulic jack?
RDavisinVA
Old December 7th, 2014, 07:31 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Originally Posted by rdavisinva View Post
Kurt:
I just clamped a 28mm rod into my vice to show about how it will work.
It's just a dummy.
Old December 14th, 2014, 03:11 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Made another adapter to support the gearbox and the transmission box as one part.
To locate the three M8 threads I used a LT77. Hope it will be the same with a R380?
This is the plate fixed by three M8 screws to the gearbox.
To handle both boxes I will use my boxlifter with the other adapter.
The combination ZF autobox/ LT230 is just on duty.
Just searching the COG to keep the boxlifter's glands in good condition.
This will take a while.
Old December 20th, 2014, 12:21 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Found the COG today.
Old December 20th, 2014, 12:23 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Awesome
Old December 22nd, 2014, 02:44 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Done!
The paint is still drying.
Old December 22nd, 2014, 04:03 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Another really nice piece of work Arlo! Love seeing how dialed your fabrication work is.
Old December 23rd, 2014, 03:47 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Thanks Don!
Form follows function and I don't want to get trapped under these heavy parts inside my pit!
The paint is dry now!
Hope Santa will not get into trouble with this monster while sliding down our chimney.
Old December 31st, 2014, 03:29 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Latest work in 2014:
an adaptor to fit a LT77 on an office chair's chassis!
Now I'm able to roll this item from one classroom to the next one without beeing breathless!
Just about 2 and a half hour to go here.
So I would like to wish you all over the place a happy new year!
Kurt
Old January 1st, 2015, 03:44 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
http://www.kraftfuttermischwerk.de/b...5/01/14254.gif
Old January 1st, 2015, 04:10 PM
carlosz's Avatar
carlosz
Carlos
wonderful craftsmanship, the shop manual tells the specs on how to fabricate those as well.
Old January 1st, 2015, 04:28 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Hi Carlos,
which manuals do you mean?
Old January 1st, 2015, 04:36 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Excellent work.
Much easier to fit than my method of chain hoist, beam through the front doors and the vehicle on car ramps!
Mike Hammond
Old January 1st, 2015, 05:24 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Originally Posted by mikeslandrover View Post
Excellent work.
Well, to get these things out, there are several solutions possible!
Found this one years ago. Source is: rainer4x4.de
Old January 1st, 2015, 06:20 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Really nice kit, Arlo. Well done and thanks for sharing.
Old January 3rd, 2015, 04:04 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
The paint is dry now.
Together with the parts of this box ...
... my pupils will have some fun when starting the next year.
I hope so.
I have to weld these broken parts or have a look for an alternativ part.
Old February 10th, 2015, 03:12 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Well, I opened the cases to get a look at all these fantastic mechanical working parts inside.
... and replaced all of the interior back to the roots!
The shifter box got glued and fixed by rails.
Hope this will be straight enough for my pupil?
Looks like a plan, no?
Old March 3rd, 2015, 03:19 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Added the LT230.
Forged links. I like this old stuff!
Some inner details:
Old April 13th, 2015, 06:01 AM
Arlo - I still really want to get one of these from you, I just need to figure out what my best lifting option is. Now that I need to change my rear oil seal, this has become more important to me!
transmission
Philips-Milner Rover V8 to Series Transmission Adapter madcowdungbeetle For Sale - Parts 6 October 19th, 2014 02:35 PM
SBF to series II transmission adapter swoodard23 For Sale - Parts 3 June 4th, 2012 06:28 PM
Cigarette Lighter adapter boshea Defender Technical Discussions 17 October 19th, 2007 05:41 PM
Steering Wheel Adapter thelandroverguy Defender Technical Discussions 19 May 8th, 2005 07:16 PM
Oil Cooler Adapter O-ring Size dnewman9 Defender Technical Discussions 0 September 5th, 2004 12:30 PM
