Transmission adapter - Page 3 - Defender Source
Old June 22nd, 2015, 04:41 PM
Nice. BTW I have an idea for a tool you might need one day - a mount to a axle housing so one man/woman can easily move an axle around on a floor jack. I could have used one today, but did it the hard way (or easy way depending on how you look at it) - got my kids to help me .
Originally Posted by pendy
I'm here for the D's
Old June 22nd, 2015, 08:50 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Lol, they just showed a howto tutorial last month on Offroad Extreme.
Old June 25th, 2015, 04:00 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Made two helper tools today:
Mounting sleeve for 4th gear assembly
Supporting device for brake C', C and D assembly, as well as 4th gear assembly
Building a tower
Old June 26th, 2015, 06:14 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Thrust washers arrived yesterday!
Old June 27th, 2015, 03:50 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Changed the method to fit the front and rear output shaft seals.
Now I use the shaft nut to press it to the needed deep.
With the conterarm positioned to the opposit side and the diff locked, it's quite easy to load the 148Nm to the central shaft nut.
Ready for transport to install the box. Input opening and breather screw are firmely closed at that time!
Old June 30th, 2015, 05:48 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Dismantling tool for one of the clutches:
This little helper is used to compress the springloaded piston to let this tiny little clip come loose:
Cylinder:
Piston:
Clutch:
Old July 1st, 2015, 06:11 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
To fit the clip I use a cone and a tube to expand it (tube is not shown)
Pressing the tube downwards the clip snaps into its groove. Can't show this either.
But just after recognizing the click it's done!
Old July 1st, 2015, 07:43 PM
Now you're just showing off!
Old July 1st, 2015, 08:13 PM
He's not showing off. But when he does, he drinks Dos Equis!
Old July 3rd, 2015, 05:43 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
What the hell is Dos Equis?
------ Follow up post added July 3rd, 2015 03:46 PM ------
Never in my mind!
Old July 3rd, 2015, 06:03 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
How to expand the frame?
I used a modified long clamp to expand the frame. This was good for about 1 or 2mm by using all hands!
This has to be changed into the smooth way!
So I welded some left overs together ...
... and will get a very strong spreading tool.
Head and bottum areas will be finished tomorrow.
Old July 4th, 2015, 01:50 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Done!
Old July 25th, 2015, 07:06 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Adapter to fit the Rocky Mountain extended oil pan.
Old August 11th, 2015, 05:07 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Adapter extensions
Figured out that my handling tool for the output shaft is about 2" too short for the Defender version!
Just added an adapter for it:
Same handicap with the tower stand:
original:
grown up version:
Supporting stand to fit the last cylinder of the inner parts (one size fits all):
transmission
Philips-Milner Rover V8 to Series Transmission Adapter madcowdungbeetle For Sale - Parts 6 October 19th, 2014 02:35 PM
SBF to series II transmission adapter swoodard23 For Sale - Parts 3 June 4th, 2012 06:28 PM
Cigarette Lighter adapter boshea Defender Technical Discussions 17 October 19th, 2007 05:41 PM
Steering Wheel Adapter thelandroverguy Defender Technical Discussions 19 May 8th, 2005 07:16 PM
Oil Cooler Adapter O-ring Size dnewman9 Defender Technical Discussions 0 September 5th, 2004 12:30 PM
