Tranny problems? - Defender Source
Old February 13th, 2011, 09:37 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Tranny problems?
Grinding in second? Sticking in gear? You may not have major tranny issues. Drop the tranny. Disable linkage. Remove the 5 10mm bolts that hold the cover on. There is an allen head set screw that moves the shaft. It can be loose or partially worn/stripped. This allows enough play where things get out of wack.
Fixed that and put the truck back together. Shifting like new.
And hay
And I love you too
problems
tranny quit on me need to source problem, fix quickly myself airbornrover Defender Technical Discussions 0 January 6th, 2009 04:36 PM
Wanted, NAS 1995 D-90 (Tranny) Transfer case Roverville Wanted 3 November 28th, 2005 02:14 PM
Wierd tranny question? D90user Defender Technical Discussions 6 November 15th, 2005 10:17 AM
Tranny leak?? mspell Defender Technical Discussions 3 September 8th, 2004 12:43 PM
Server Connection Problems chrisvonc Community News & Announcements 1 July 25th, 2004 10:22 PM
