Trail Rash - Defender Source
Old May 1st, 2013, 05:21 PM
WD90's Avatar
WD90
Dan
1995 NAS Defender 90
Trail Rash
I need some suggestions on how to fix this... will I need to replace the panels, or can this be smoothed out somehow...
-Dan
Old May 1st, 2013, 05:33 PM
Dan, no suggestions here , but how did you get such trail rash with that cage?
Old May 1st, 2013, 05:34 PM
Leave it. You best option is a full tub side as no other way to get the spot welds, but then the 18 year old paint won't match the new etc.
Old May 1st, 2013, 05:40 PM
WD90's Avatar
WD90
Dan
It's damage that happened before the cage was added...
Old May 1st, 2013, 08:38 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Hey that looks like mine! Taking it to see what my body shop can do! Ill let you know.
ID:	71233   Click image for larger version
Old May 1st, 2013, 10:33 PM
My understanding is that should buff out ?
Old May 2nd, 2013, 11:06 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Bones Heal and Chicks Dig Scars!
Leave it, its a Defender, not a '13 Range Rover!
Old May 2nd, 2013, 11:25 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
x2
~stv
Old May 3rd, 2013, 02:49 PM
WD90's Avatar
WD90
Dan
Ouch, Brewie!
Mine is actually the result of the Defender rolling over on its side in a parking lot during one of the original owner's drunken stupors... There's slight damage going down the entire side of the vehicle, but the worst is in that rear panel.
I may just leave it, I have a lot of customers that see my 90, and I always give them a good "excursion story" of how it got the dents... I think it would be ok if I did the damage myself...
Old May 3rd, 2013, 03:16 PM
The spot welds can be drilled out and the rivets chiseled off the cappings allowing the entire panel to be removed. The spot welds should be done from the outside so that the flanges inside are not drilled. Installing the replacement panel is done with PanelBond adhesive which will be far superior to the original weldment in strength. IDK where to get the panel but I know they are available.
I would leave it myself. It's part of the vehicle's history no matter how ignominious. It may be somewhat humorous to put a large band-aid over the hole, and write "ouch!" with a paint pen.
Old May 3rd, 2013, 04:46 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Just to add to Bill's comment; Eastwood has a spot weld removal tool and an add on for a regular mig welder to spot weld. I haven't tried them out yet put it looks pretty cool.
Old May 3rd, 2013, 04:54 PM
WD90's Avatar
WD90
Dan
I was kinda curious if it would be possible to get the spot welds back in the right spot. I'm sure a seasoned enthusiast would spot the missing spotwelds rather quickly.
Old May 3rd, 2013, 05:15 PM
Canol109's Avatar
Canol109
Dave
1991 Defender 110
Panel
I know it is not the correct side, but they are out there if you decide to fix it
http://www.ebay.co.uk/itm/Land-Rover...item27d270042f
Alternatively you could clean it up the best you can and skim it with bondo and repaint.
_______________________________________________
1991 x-MoD 19 KK 88 Defender 110
1965 x-MoD 35 ET 73 Sankey Narrow Track Trailer ~
1955 Series 1 86 Hardtop 173601415
1955 Series 1 86 Hardtop 57130577 ~ just a heap o' parts now
1985 Series III 109 x-MoD BATUS 77 KC 63 < sold
Old May 3rd, 2013, 05:25 PM
WD90's Avatar
WD90
Dan
Yeah, that crossed my mind
Skimming that small little bit after a little more hammering would be so bad?
28th Annual Hump N Bump 7&8 Nov 2008 - Las Vegas BCR Trips, Trails and Events 4 December 11th, 2008 06:59 PM
Report Trail Abusers! jimbemotumbo Trips, Trails and Events 2 May 23rd, 2005 04:20 PM
1995 Discovery 300TDI, Trail Ready.... Joe B For Sale - Vehicles 1 June 23rd, 2004 06:26 PM
Hackett/Longwater (1999) - Colorado USA chrisvonc Trip & Trail Reports 0 June 19th, 2004 10:44 AM
Trail run 5/7 CO. TwisteD90 Trips, Trails and Events 0 May 5th, 2004 06:43 PM
