Thread sealant? - Defender Source
Old June 14th, 2016, 05:58 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Thread sealant?
What should I use to seal these threads?
I've never had this pipe off before...
Rent my
Old June 14th, 2016, 06:40 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Aircraft form-a-gasket #3 - the brown stuff in a can with a brush on the inside of the lid.
Available at most auto parts stores - NAPA has it for sure.
That or Loctite PST - Thread sealer with Teflon.
Old June 14th, 2016, 09:27 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Thanks Jack!
Rent my
Old June 14th, 2016, 10:11 PM
Naplm00
Matthew
I prefer the arp stuff
https://m.summitracing.com/parts/arp-100-9904
Old June 15th, 2016, 07:27 AM
Originally Posted by Naplm00 View Post
i've had good results with this as well
Old June 15th, 2016, 07:57 AM
I would probably use the white thread sealant that Permatex makes.
300tdi bellhousing sealant??? Wilboro Defender Technical Discussions 5 November 7th, 2015 01:17 PM
thread sealant JBOD77 Defender Technical Discussions 11 April 2nd, 2009 02:35 PM
Plenum to air intake sealant rgrrvr Defender Technical Discussions 0 June 1st, 2007 09:26 PM
Block sealant (was coolant gasses in rad) Davis Defender Technical Discussions 6 April 6th, 2006 01:08 AM
Head Bolts. Sealant? or no sealant? Hans Defender Technical Discussions 1 January 19th, 2005 11:42 PM
