Third row seats in 2012 Puma - Defender Source
Old January 3rd, 2018, 03:17 PM
HMJ's Avatar
HMJ
Magnus Johannsson
2012 Puma
I have installed the third seat row in my 2012 Puma. Original seats and everything looks good. I have the bracket that goes into the top corner to fasten the seat belts. However, I struggle with how to fasten the belts below. From photos that I´ve found on the web it seems that the belts are fastened on the "shelf" (scuse my english) and not the floor itself. And from more googling I´ve found that there are L-shaped brackets that (I think) need to be installed underneath the whole thing. My Puma does not have these L-shaped brackets installed. Whether the seat belt screws into these brackets or not, I have no clue. I basically have no idea what I should screw these seatbelts into. Attached are three photos, one which shows my Defender lacking this bracket, another with it installed and a third photo is off the web.
Is this bracket neccesary? Do I fasten the seat belt to this bracket? Or is there some other hole I’m missing?
Grateful for all comments.
ID:	342313   Click image for larger version
Old January 3rd, 2018, 05:05 PM
Mendicant
Yes, you need that support that goes under the tub with the tube that bolts down to the rear crossmember. Once you get this it should be more self-explanatory.
Old January 3rd, 2018, 06:19 PM
HMJ's Avatar
HMJ
Magnus Johannsson
2012 Puma
Thanks Jim. Just needed that confirmation. But does the belt screw into the bracket?
Old January 3rd, 2018, 06:35 PM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
https://www.landroverworkshop.com/di...ar-seats_45090
No idea on belt location. Check UK forums.
KGH - “Stinky LR diesel” Defender Snob
Old January 4th, 2018, 04:15 AM
HMJ's Avatar
HMJ
Magnus Johannsson
2012 Puma
Well - guess what.. This bracket is out of stock - permanently. Have checked Paddock and Craddock and Lrparts and Britcar *sigh*
If anyone has a good idea for where to get it, I´m all ears!
Old January 4th, 2018, 05:16 AM
KGH's Avatar
KGH
Real Name
Post a “wanted” add on ebay.co.uk, or on a UK forum such as Defender2
Old January 23rd, 2018, 03:11 PM
HMJ's Avatar
HMJ
Magnus Johannsson
2012 Puma
Thought I should “report” back. I couldn’t find these brackets anywhere until I was referred to Matt at a used parts sale “Carriages auto service ltd” in the UK. You’ll find them on facebook. He had them, sent them, I got them - and I actually installed them myself! Recommend them.
Fridge install in 110 2nd row between seats Overlander Defender Technical Discussions 20 November 21st, 2017 01:28 PM
In from Dubai! 2012 PUMA Leather Foward Facing Side-Folding Rear Seats Abu Buckwheat For Sale - Parts 5 May 7th, 2014 12:01 PM
Exmoor Trim USA new middle row 110 seats sneak peek ExmoorTrimUSA The Vendors Loft 32 November 18th, 2013 09:20 PM
Puma Front & Middle Row Seats jjstahl3 For Sale - Parts 4 July 22nd, 2013 08:07 AM
ROW Middle Row Seats Wolf Fabrication For Sale - Parts 10 May 24th, 2011 06:00 PM
