Third brake lamp?? Suggestions needed! - Defender Source
Old February 23rd, 2016, 11:27 AM
Azarur
AZ
LR 1984 110
Hi all,
Need suggestions (with photos preferably!) of what to use for third brake lamp.
Truck is a 110 with the spare tire on swing gate behind fifth door.
Options are:
- Gadget that mounts behind spare tire
- Gadget that mounts above license plate
- Gadget that mounts on the top of the fifth door
Any others that people find cool?
Please help... we are out of ideas *truck remodel exhaustion kicking in*
Old February 23rd, 2016, 01:06 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
3rd Brake Light
I used a Truck-Lite trailer lamp, has both running & brake lamp LED's in it.
I only wired in the brake lights. It's been in since 2000 and all the LED's still light up.
Cut a hole in the metal with a hand nibbler & JB Welded it in.
On the outside I used black silicon sealant to keep the weather out.
Also moved the washer over to the left slightly.
Name:	AAA LED Brake Light.jpg
Old February 23rd, 2016, 01:44 PM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
I used a rear window mount led one from Ron Francis Wiring. Discrete, bright and no cutting required. The small wiring is easy to hide in the window channel under the trim pieces making for a tidy install.
https://www.ronfrancis.com/prodinfo.asp?number=RW%2D43
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old February 23rd, 2016, 01:53 PM
Azarur
AZ
LR 1984 110
Thank you both. I would prefer no cutting. Having said that I do like the look on Viton's truck!
Old February 23rd, 2016, 01:58 PM
pitchrollyaw
wayne p
1985 d90 2.5NA
Originally Posted by Azarur View Post
.....I do like the look on Viton's truck!
Me too, but I don't like cutting either.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old February 23rd, 2016, 11:03 PM
Bolson
Ben Olson
1995 Defender 110
Third brake light
I used one from our local truck outfitter place ( cap-it) . it's a replacement one for a leer commercial canopy
Looks like this
Old February 24th, 2016, 12:03 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
That's my favorite part of the freeloader!
Cheap and great solution. And it does say "Land Rover," so noobs won't notice that anything is amiss!
Old February 24th, 2016, 12:23 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I plan to use a surface mout low profile. Similar to this, but probably not as wide. https://www.superbrightleds.com/more...-tlb-r11/1027/
Old February 24th, 2016, 06:29 AM
Azarur
AZ
LR 1984 110
Love the freelancer idea. Looks cool. Where would you mount it in the 110 though
Old February 24th, 2016, 11:00 AM
D90Overkill
David Frank
1995 ST #2615
Didn't you say you had a rear spare carrier? Mount it "freelancer style," around the tire.
Old February 24th, 2016, 11:08 AM
Azarur
AZ
LR 1984 110
I think the spare on the 110 may be way too big. I'll try. Otherwise I may mount it inside the rear door...
Old February 24th, 2016, 11:12 AM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
I think its the only redeeming quality of the whole truck.
-Jeff
Roll down rear window as well.
Old February 24th, 2016, 11:29 AM
greenmountainrover's Avatar
greenmountainrover
Derek Chace
84 Lightweight FFR
I did one for a 90. Figured with client driving around Boston all the time would help out. I'll try and dig up a picture.
Green Mountain Rovers your Defender/Series sales and importation specialist.
802-655-4874
brake, lamp
WTB Cabin Lamp - Dash Lamp isleofbones Wanted 0 March 9th, 2013 05:55 PM
License Plate LED Lamp & Rear Fog Lamp Install LenB Smaller Projects 24 December 16th, 2007 08:54 PM
'94 D90 -- Third brake light? rmuller Defender Technical Discussions 2 September 9th, 2007 09:50 PM
Looking for new third - high brake Light Shake Wanted 4 February 13th, 2007 10:17 PM
third brake light bar Marc Weinstein For Sale - Parts 0 April 16th, 2004 08:03 AM
