The Start of Something Bigger (4.6) - Defender Source
Old March 29th, 2014, 11:25 AM
bradfordish's Avatar
bradfordish
Bradford
95 D90 SW #141
I've been feeling the 4.6L itch for a while, and Jimmy (Jymmiejamz) finally helped push me over the edge.
The plan:
4.6 block
4.6 crankshaft
4.0 pistons
Crower stage 2 cam
Jet Hot coated exhaust manifolds
Magnaflow y-pipe
Mark Adams Tornado chip
Old March 29th, 2014, 04:47 PM
The Dro
Dro
1988 Ninety
I like what he did with the plenum.
If I ever go the 4.6L route again... I'll copy his idea.
Old March 29th, 2014, 04:50 PM
KKilo23's Avatar
KKilo23
Kenny
And whats that??
I am going 4.0 to 4.6 in my 1997 as we speak.
Old March 29th, 2014, 05:19 PM
The Dro
Dro
1988 Ninety
Originally Posted by KKilo23 View Post
And whats that??
It's just Rover Porn...
He polished the top part and added a Land Rover logo where the 4.6L was.
Old March 29th, 2014, 07:21 PM
defender1844
Amit Likhyani
Doing the same thing. I bought a 4.6 from a 2003 Discovery and I'm using those pistons. I am working with aluminum v8. Bought the T cylinder liners, crower cam, hot coil and distributor, bolt kit, chain. I have the Maganflow y-pipe. I also bought the headman headers and they aren't going to bolt right up to the y-pipe. What do people recommend? Should I sell the y-pipe and have a muffler shop start over from the headers back? Should I sell the headers and just use the OEM manifolds? Or is there something else I should consider?
Old March 29th, 2014, 07:32 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Cha...wannabe D90 racers! wait until my 5.2 goes in...when I die from 360 HP in a D90 it will be because I was able to exceed 85 mph uphill!
Old April 3rd, 2014, 10:55 PM
robertf
Robert F
1995 Discovery
The plan:
4.6 block
4.6 crankshaft
4.0 pistons
Crower stage 2 cam
Magnaflow y-pipe
Which one is the stage 2? I did the 50229 in mine with 4.6 pistons. I really think a stock 4.6 cam grind would be better with 4.0 pistons. If you go by dynamic compression ratio the cylinder pressures will be huge compared to stock with a reasonable crower cam and 4.0 pistons. The 4.6 cam has a lazy intake closing angle that would bring the dynamic compression ratio with 4.0 pistons similar to stock at low RPM and a much larger power band. I'd be worried about detonation with a 50229 or 50230
Old April 3rd, 2014, 10:58 PM
How did I miss this thread previously? Subscribed. When do we start the motor pull ?
Old April 4th, 2014, 12:05 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
How many HP will it have?
What are you going to do to prevent slipped cylinder liners?
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old April 4th, 2014, 08:38 AM
We're going to build the engine mostly complete so it will be a quick swap. That way we can clean and paint everything without having the truck apart for weeks. It takes a long time to paint all of the pieces of the motor. Fortunately, between my co worker Drew and I, we have enough pieces to build the motor without using most of his existing stuff.
This is what Pedro is talking about on my plenum. I can't take credit for this since Drew came up with the idea and and gave me that intake to put on this motor for my RRC. I love the way it looks, and its way cheaper than a 4.6 plenum.
Since a 14CUX plenum is not flat we're going to do something different. I'd like to have the 3.9 machined off of it, and will probably paint it like my D90's motor (PO painted it).
Old April 4th, 2014, 06:47 PM
defender1844
Amit Likhyani
Please let me know what you end up doing to your plenum. I definitely want to grind off the 3.9 and maybe have a plate made that says 4.6. I'll polish the plenum too while it's off. Open to other ideas as well obviously.
Old April 29th, 2014, 12:08 PM
bradfordish
Bradford
95 D90 SW #141
Jet Hot coated valve covers and exhaust manifolds are in and looking great!
ID:	93929   Click image for larger version
Old May 23rd, 2014, 09:47 AM
bradfordish
Bradford
95 D90 SW #141
More progress... New cadmium plating on the fuel rail. Block and crank back from the machine shop.
ID:	95611   Click image for larger version
Old May 23rd, 2014, 09:58 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
#roverporn looks amazing
Old May 27th, 2014, 06:02 PM
Very nice, digging the plenum.
Old May 27th, 2014, 10:05 PM
Which one? Neither of them are going on Brad's, but I've had the 3.9 machined off of a 14CUX plenum. I'm working on the rest of the motor, so the plenum is kind of the last this I'm worried about at the moment. I'll be getting the truck on thursday, so there should be a lot of updates from now on!
Old May 30th, 2014, 07:29 PM
Coming together...
Note: The sandblaster is not being used with the engine in the building.
Old May 30th, 2014, 08:36 PM
RoverDude
John Gadd
Many
Did you consider headers?
Old May 30th, 2014, 10:08 PM
No. In the limited experience I have with aftermarket headers, they never fit properly. The factory manifolds work fine, and this motor will have plenty of power without headers.
Old May 31st, 2014, 12:45 AM
i like the "shaved" plenum.
start
Bigger radiator on a 4.6 JFD Defender Technical Discussions 3 November 3rd, 2011 09:23 AM
more powerful power steering pump and a bigger reservoir cdb Defender Technical Discussions 10 June 14th, 2010 11:16 PM
bigger sway bar for rear CDeWan Wanted 0 May 15th, 2009 07:14 PM
for when you change to bigger tires 1000kva Misc. Chit-Chat 1 September 24th, 2007 08:19 AM
bigger RIM's rover4x4 Misc. Chit-Chat 25 March 10th, 2005 10:06 PM
