Tdi RPMS - Defender Source
Old February 25th, 2015, 01:10 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Tdi RPMS
I know there's a few Disco/RRC tdi conversions on here. I can't figure out why my RPMS are so high.
It's a 300/R380/28D 1.2 box.
Can't tell if it's incorrect alternator signal to the tach or what, but my truck screams at 75 it seems
Anyone else have this issue? According to Ashcroft the RPMs should be quite a bit lower
Old February 25th, 2015, 01:21 PM
BRAB
Brandon
200TDI in a RHD 1986 D90
Just rev it excessively while standing, that should solve your problem
Old February 25th, 2015, 01:28 PM
You sure you have a 1.2 speedo gear in the tcase? Maybe whatever the tcase was in before had a 1.4 or 1.6 gear in it. That reading would still be high for 1.4, but 1.6 I'm guessing about right.
I actually confirmed my tach reading with an iphone app that listens to the engine noise and gives you a tach reading back. they have them for droids too.
Mark Kellgren
KM4BOR
Old February 25th, 2015, 01:31 PM
Pick up a laser tach. They are cheap and you can know what is going on instead of guessing and then go from there.
Old February 25th, 2015, 01:36 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
T-case came from a 300tdi setup which should have the 1.2 case, no reason to think it's off. Speedo is +/- 2% according to GPS
Cheap one is fine? Digital Photo Sensor Tachometer
Old February 25th, 2015, 01:37 PM
the rover shop
shayne young
Take it out of low range..
------ Follow up post added February 25th, 2015 01:38 PM ------
I know it's possibly a stupid question.. But you do have 3:54 diff gears right..??
Old February 25th, 2015, 01:39 PM
Have a look at the serial number of both boxes. No chance axle ratios have been changed? This is a D2? Speedo uses the ABS sensors, so does not care about any drivetrain ratios.
Sure. Mine was maybe $15 and works great.
Old February 25th, 2015, 01:41 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Low range is not the issue
Yes, 3.54 stock gears in the truck
------ Follow up post added February 25th, 2015 01:42 PM ------
The serial number on the t-box started 28DXXXXXX, so it should be a 1.22
It's on the D1, so speedo is out of the back of the case. Speedo is mostly accurate within a couple percent.
Old February 25th, 2015, 01:43 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
stupid…this is a d1 right...
Old February 25th, 2015, 01:45 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I don't recall the 95 D1 having SLABS?
Old February 25th, 2015, 01:48 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
yeah, thought it was a d2…stupid
Old February 25th, 2015, 01:49 PM
the rover shop
shayne young
Come on guys...d1 instruments.... D2 was digital odometer..and what's this about slabs...all I see is an anti lock and srs lights...
I have had to move dip switches on vdo tachs before to get accurate readings.
What does the tach say idle is ?
Old February 25th, 2015, 01:51 PM
I have the exact same problem with my 200tdi.
I run 3.54 gears, 1.222 (as marked) LT230, and an early LT77.
At 70-75 mph I'm already at 3500ish rpm, which seems high to me (and makes quite a din)
I'm thinking that it would be pretty obvious (especially on a tdi) to zack if his engine was indeed at 3k rpm.
Old February 25th, 2015, 01:53 PM
Somewhere Zack has just been pulled over for going 60 in a school zone.
Officer: Do you have any idea how fast you were going?
Zack: 24mph officer, per my speedo
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Idle shows around 1100 after warmed up.
------ Follow up post added February 25th, 2015 01:54 PM ------
Better having it off than before Kraig sent me the wiring harness and I had NO speedo haha
Old February 25th, 2015, 01:58 PM
tdi and v8 used same tach if both have airbags. The non air bag tdi used STC2968. The airbag tdi and fi V8 with airbags both used STC2969.
1100 @ idle would be way high. Its more like 600-700. Sounds like you are reading 4-500 rpm high.
Old February 25th, 2015, 02:12 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
If you have a 1.2TC you need the 61mm pulley for the alternator.
1.4TC and you need the 49mm pulley. I had the same mistake
STC1796 - I can have RN bill you if you want... wait what?
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 25th, 2015, 02:27 PM
Originally Posted by ini88 View Post
If you have a 1.2TC you need the 61mm pulley for the alternator. 1.4TC and you need the 49mm pulley. I had the same mistake STC1796 - I can have RN bill you if you want... wait what?
Huh? How can the transfer case have anything to do with the tachometer reading?
Old February 25th, 2015, 02:29 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
tdi
RPMs die, then vehicle stalls at next light. sro Defender Technical Discussions 19 November 22nd, 2012 09:23 PM
Knocking when low RPMs but Accelerator depressed near floor rijosho Defender Technical Discussions 6 August 1st, 2011 03:32 PM
Engine loses power at 2500 rpms Hazard Defender Technical Discussions 17 October 15th, 2010 04:57 PM
Engine sweet spot and highway RPMs cgalpin Defender Technical Discussions 32 December 30th, 2009 12:02 PM
misfires at low rpms sometimes jdb3760 Defender Technical Discussions 1 December 3rd, 2006 09:50 AM
