Tdi RPMS - Page 3 - Defender Source
Old February 25th, 2015, 04:01 PM
Originally Posted by Red90 View Post
Good lord.....
The engine runs the alternator, which sends the signal to the tach. It does not matter what is in the rest of the drivetrain. Low range, high range, engine on a stand. It will still read the same.
The drivetrain has NOTHING to do with the tachometer signal.
Alternator pulley size and number or poles is all that matters.
Yep. I retract everything I said. I was thinking speedo. All tachs read off the alternator.
Mark Kellgren
KM4BOR
Old February 25th, 2015, 05:16 PM
RBBailey
RBBailey
1965 IIa
Good lord.....
if the drive train is causing the higher RPMs in the engine -- having a higher rev due to a lower gear ratio -- then the alternator will also be running at a higher RPM, thus sending the signal that there is a higher RPM. Unless the RPM of the alt is not how the reading is measured. I was assuming it was getting it's info from it's own RPM.
I don't know if this helps him solve his issue, though, I was only trying to reword what others were saying.
And I don't disagree with you, I think we are simply looking at it from opposite ends. I could be totally wrong, but someone will have to explain to me how there is some kind of clutch mechanism to keep the alternator at a constant speed, despite what the engine is doing, and that the measurement from the alternator does not come from a measurement of it's own RPM's, which are tied to the engine speed, which is tied to the gear ratio.
Project:
1965 IIa SWB
Old February 25th, 2015, 06:32 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Lol. Classic misunderstanding of fundamentals thread. Love it.
Old February 25th, 2015, 06:40 PM
the rover shop
shayne young
Zack... Put the bigger pulley on it and be done with all this tomfoolery..
Old February 25th, 2015, 06:52 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
yes, put the big pulley on and drive it faster since you will have more RPMs to use
Also you swear you have 3.54 diffs in? or maybe 4.11s?
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 25th, 2015, 07:07 PM
the rover shop
shayne young
Quite simply he needs to verify engine speed is same as tach reading... Everything else is a different problem..
Old February 25th, 2015, 07:12 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I have 4.11s in my d2, if I had 4.11s in the d1 I'd be at 5k at 60!
Old February 25th, 2015, 07:34 PM
Which is what I said on the fourth post but everyone cannot resist coming on and confusing the situation.
Old February 25th, 2015, 07:51 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I am glad there a few people on here that knows what they are talking about, that's some funny shit about gear ratios. Don't forget that using helium in ya tyres will change that alt speed, LOL
Get your self a hand held tachometer and be done with it. or if you have a timing light and a another vehicle with petrol engine you can match speeds with each other. should read the other vehicle needs to have a tach fitted
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old February 25th, 2015, 08:11 PM
Are you sure you don't have 4.10's in the transmission RPM speed sending unit?
Old March 13th, 2015, 05:17 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Originally Posted by Z.G View Post
I know there's a few Disco/RRC tdi conversions on here. I can't figure out why my RPMS are so high.
It's a 300/R380/28D 1.2 box.
Can't tell if it's incorrect alternator signal to the tach or what, but my truck screams at 75 it seems
Anyone else have this issue? According to Ashcroft the RPMs should be quite a bit lower
ZG, I was reminded of this thread this morning...
300tdi+ZF.auto+245/75KM1s
2500-2600rpm @70-72mph
It'd be nice to grab a 5th gear sometimes...
But not *screaming*.
I will say the Tdi is a "buzzy" little motor
Rent my
Old March 13th, 2015, 05:28 PM
Have you looked at getting a TDi instrument pack, Jeff?
Old March 13th, 2015, 05:31 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Thanks Jeff, good to know.
Old March 13th, 2015, 05:48 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
What is a Tdi instrument pack?
Rent my
Old March 13th, 2015, 05:58 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
The cluster
Old March 13th, 2015, 06:40 PM
I assume it would have a different tachometer.
Old March 13th, 2015, 07:30 PM
I think we had the discussion above that the tach part numbers are the same for V8 and TDI.
Old March 13th, 2015, 07:41 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Charlie H. aka the Rover Whisperer told me all the V8 stuff was fine...plug n play.
My rpms seems dead on.
I just dropped in the Tdi and used the existing wiring...alls good.
Now...I did add on a EGT and a PSI guage extra.
Zack, what's yours reading these days?
Rent my
Old March 13th, 2015, 08:11 PM
I know it reads correctly, but the range would be different. A Tdi cluster would probably only go to 5k or so RPM's.
Old March 13th, 2015, 08:40 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Don't hate the playa...
I just put a dual pod in the coin tray 😊
Rent my
tdi
RPMs die, then vehicle stalls at next light. sro Defender Technical Discussions 19 November 22nd, 2012 09:23 PM
Knocking when low RPMs but Accelerator depressed near floor rijosho Defender Technical Discussions 6 August 1st, 2011 03:32 PM
Engine loses power at 2500 rpms Hazard Defender Technical Discussions 17 October 15th, 2010 04:57 PM
Engine sweet spot and highway RPMs cgalpin Defender Technical Discussions 32 December 30th, 2009 12:02 PM
misfires at low rpms sometimes jdb3760 Defender Technical Discussions 1 December 3rd, 2006 09:50 AM
