TD5 speedometer install help - Defender Source
Old April 2nd, 2008, 11:29 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Guys,
I have got my hands on a Td5 speedometer and & gauge panel with the wiring harness still attached, I also have got some schematics on the pin-outs for the connector.
I have a 94 D90 ST, what I need is a schematic of the pin-out for this truck or If someone has done this before then even better if they can point me in the right direction.
As an added bonuse I also have the "black out LED indicator panel" as seen in ECR's website, man if I can also get this working it would be great,...
I have a detail pictures attached:
and
Well this is what I have so far, any help would be great.
Old April 19th, 2008, 03:24 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
There has been a good bit on a similar thread here in the UK on LR4x4.
for the speedo install, you want the wibbly wobbly speedo thread which covers the speedo and later on, some of the warning light binnacle wiring.
Also attached is (should be!) a .zip .xls spreadsheet with the wiring pin-outs for the later Td5 type dash.
Old April 21st, 2008, 07:30 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Thank you very much "diesel_jim" ..I will work on this project now.
All the best
Tom
Old April 23rd, 2008, 07:25 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
No problem.
Shout if you need any tech help on it, although most of the info is there in that link.
Jamie.
Old April 23rd, 2008, 12:43 PM
DJ - there are pix of your build at lr4x4 but nothing good here. I recommend you fix this problem by posting lots of pix here. Otherwise, I will be forced to use another site to view sufficient roverpr0n and that would require extra clicking.
Old April 26th, 2008, 07:13 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
LOL!!!
OK, i'll get some fresh piccies up on here. actually, not much has changed in the last month. the weather has been crap here (UK) and as i'm building it out on the drive, i'm quite weatehr dependant.
anyway, i'll get it updated ASAP sir!
Old April 27th, 2008, 03:47 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
AHHHH your the best man..
speedo, td5
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
Correcting speedometer after lift/tires Seriesman Defender Technical Discussions 16 November 24th, 2005 08:37 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
TD5 versus 2.8L PS jaherring Defender Technical Discussions 12 April 21st, 2005 05:49 AM
Maybe FS: 1999 Defender 110 Td5 mlepisto For Sale - Vehicles 3 March 18th, 2004 02:17 PM
