swivel ball castor correction service available - Defender Source
Old February 19th, 2016, 08:34 AM
ezzzzzzz
Mark Garrenton
I'm offering castor correction for your swivel balls, new or used. Up to 3.5 degrees of correction with anti-rotation inserts. This will accommodate 2"-3" lifts bringing castor close to .5 degrees of factory. This will aid any lifted vehicle above 3" of lift too. I can machine for more correction but there won't be adequate room for a proper diameter anti-rotation insert beyond 3.5 degrees. Cost per pair is $120 with inserts or $100 without inserts.
Attachment shows 3.5 degrees correction with opposing anti-rotation inserts. Face milling of flange (shown) will not be done as it is unnecessary.
Name:	P2181355 (Small).JPG
I need to go back to work for the break. Retirement is exhausting!
'71 IIA 88" LS1 hybrid
'84 110 5 door 'Nigerian Princess'
'90 RRC
'97 D1 LSE (parting out)
'02 D2 Kalahari
'02 D2 SE
'02 D2 SE
service
Castor Correction Advise Sought… LRNAD90 Defender Technical Discussions 13 July 30th, 2013 02:54 PM
Fixing Castor:Radius arms. vs. Swivel Ball sflash868 Defender Technical Discussions 15 August 10th, 2011 04:01 PM
Castor correction rover4x4 Defender Technical Discussions 3 May 12th, 2007 10:38 AM
OME castor correction bushings Overlander Defender Technical Discussions 3 January 4th, 2007 04:45 PM
Castor correction and rear end steering D90user Defender Technical Discussions 0 August 12th, 2006 02:26 PM
