Stereo install - Page 2 - Defender Source
Old October 29th, 2012, 09:25 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Really? Mine were in the doors.
Old October 29th, 2012, 10:44 PM
discotdi
Todd Miller
Land Rover
ROW trucks had them there. Yours is an NAS truck. Without air then speakers were in the lower part of the dash
Old October 30th, 2012, 12:22 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
IIRC the hole is sleeved I think. It's not open to the cooled air inside as there is an inner wall around the hole.
Old October 30th, 2012, 02:37 AM
Yudda's Avatar
Yudda
Rob
1997/300tdi/110
Originally Posted by DMSLongLake View Post
Thank you.
That's exactly what I'm looking for except,
I'm concerned with the quality.
Also I thing I can plug a Bluetooth dongle to the 3.5 input !
Thanks again.
Old October 30th, 2012, 08:24 AM
Howski's Avatar
Howski
Kevin
2002 Land Rover Discovery II
Is there anything similar to this where you could run 4 speakers?
Old November 4th, 2012, 10:17 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Just got all the electronics together... Waiting for my new black door panels and then we begin the fun...
Old November 4th, 2012, 11:02 PM
With a 2 ohm amp you have plenty of options for running more than 2 speakers. Call crutchfield and ask them for advice.
Old November 5th, 2012, 11:19 PM
Lemonhead
TB
1997 D90 SW
I went for a Fusion marine stereo that has a wired remote that I was able to mount on a gooseneck so I have easy access to it below the clock (in the "cut-out" area in front of fuses). The remote is genius since it actually has a volume knob instead of just buttons. Also replaced all four speakers with JL Audio 6.5's and put a Sound Ordinance powered sub under the passenger seat (fits tight, but fits).
Still some tweaking to be done - Bass better than expected - A little weak on the mid bass as doors and rear enclosures don't help the cause.
The Fusion doesn't have bluetooth (because it's a marine stereo) so I purchased a simple Parrot set-up that I have to integrate into the system for hands-free calling. Cool part about the Fusion is you stick an iPod in it, so access to plenty of music.
I will post pictures at some point if anybody is interested.
Sub - http://www.crutchfield.com/p_777B8PT...nce-B-8PT.html
6.5" - http://www.crutchfield.com/p_136TR60...TR600-CXi.html
Stereo - http://www.fusionelectronics.com/mar...eries/ms-ip700
Remote - http://www.fusionelectronics.com/mar...otes/ms-nrx200
Old November 5th, 2012, 11:33 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
I just got the kicker px50.2 and should have it up and running soon. I'll post my findings. For me it was a great option as I don't have a head unit or speakers so I run just this.
Old November 6th, 2012, 08:20 AM
Howski's Avatar
Howski
Kevin
Let us know how it works
Old February 13th, 2013, 10:10 AM
Yudda's Avatar
Yudda
Rob
1997/300tdi/110
Anyone install that Kicker setup ? How is it ?
thanks.
Old February 13th, 2013, 01:25 PM
El Solis's Avatar
El Solis
Chris Solis
So finally got the truck together and installed the kicker system. Works well. I have a very loud landrover 110 with Diesel engine and paired it with el cheapo $30 all weather speakers and it works great. Gets way louder than I can listen to it without distortion. I can hear it clearly over engine and road noise and its a simple install. Although I had to go and make it difficult by putting the amp in the back inside my fuse box
Control unit up front on the dash
I did have to buy an extension for the 3.5mm jack line and make my own extension for the power to the control unit but that wasn't a big deal.
Old February 13th, 2013, 02:22 PM
Yudda's Avatar
Yudda
Rob
1997/300tdi/110
Chris,
I think you could add one of these
http://www.ebay.co.uk/itm/1209493362...84.m1438.l2649
connected to the apple connector ...and have Bluetooth streaming.
At least that's my plan
Thanks for the update.
Old February 13th, 2013, 09:45 PM
El Solis's Avatar
El Solis
Chris Solis
The iPod sits on the amp so the extension is for the control unit. That connects to the system via a cable with a 3.5mm plug and a bullet connector end wire for powering the blue back light.
Old August 16th, 2014, 10:34 PM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
Originally Posted by BMGmotors View Post
I am pretty satisfied with my stereo system in my daily driver D90, I have some 6" or 6.5" Boston Acoustic speakers in the door panels, some sort of Kenwood speakers in rear and some tweeters behind both front seats in the corners kind of where the capping meets the doors seals but of course inside the truck. I also have the stock Clarion radio with an auxiliary cable option attached so I can play music from my Iphone. The OE radio + ipod dock I got from John at gb4x4radios.com sounds great, I would like to add a subwoofer someday though. I have a soft top D90 though, so your LE should be much quieter, so I'm told. Shoot John an email, he has an LE as well which has a great sounding system in it, I've heard it. Not sure how much your wanting to keep the "stock" look but I think the Clarion radios+Ipod capability that John offers are a great compromise. I too am somewhat of an audiophile but have not yet figured out a feasible way of installing a Rega turntable in my 90, ha. Hope that helps.
Any advice on removing the stock stereo?
Old August 17th, 2014, 12:12 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Piece of cake to remove. It might simply pull up from the console, but pull from the cassette mouth. If not, use a very small Phillips screwdriver or straighten a wire hanger and push into the two small holes at the top edge and release the holding clips. Remove the head unit from the cassette mouth. Remove the connectors at the rear. Don't cut those connectors, but use the proper adapters for the new radio you wish to install.
If you want to sell the original head unit please PM me.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old August 17th, 2014, 12:19 AM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
Thanks for the reply. I tried to place a small Phillips in each hole and couldn't get it to release. Will try again!
Old August 17th, 2014, 12:42 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Gravity may be working against you. Try a wire hanger, straighten both ends and try to make it so that you can push into the two holes at the same time, release and pull.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old August 17th, 2014, 06:27 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Not sure which defender you have. But try to go through the cubby. Open your cubby storage door, Remove the screws holding the cubby tray, then reach for the radio.
The radio will be in its own tray, secured with pop up finger tabs that will prevent the tray from sliding out by pressing up against the cubby ceiling.
Reach in towards the radio tray, feel around the tray on all sides, push those finger tabs in while you pull up on the whole radio with your other hand. It's a little pain, but you'll get it
Old August 17th, 2014, 09:33 AM
Your new stereo should have come with the tools to get your current stereo out. You can look it up on YouTube as well.
stereo
Stereo Install Questions jefferson Defender Technical Discussions 14 November 3rd, 2013 02:01 PM
Beautiful 1994 D90 - Stereo Install Ideas! CDN90 Misc. Chit-Chat 15 June 8th, 2010 06:28 PM
Stereo Install In Dash caschumann Defender Technical Discussions 18 November 4th, 2004 12:41 AM
Hitch/ pull point install question JKM Defender Technical Discussions 3 May 18th, 2004 08:39 AM
D110 Stereo wiring pcarey Defender Technical Discussions 1 November 23rd, 2003 10:57 PM
