Steering tie rod - Defender Source
Old June 16th, 2015, 08:07 AM
huibae's Avatar
huibae
Harold Lee
Jon Snow Badge 1122
Steering tie rod
Noticed my 90 pulling to the left when braking hard. Thought it was a stuck caliper but the tie rods were super loose and unstable.
Need to replace. Anyone got a step by step. Also, can I just replace the tie rods or do I have to replace arms and crossroad tube also.
Harold
ID:	123004   Click image for larger version
Old June 16th, 2015, 08:14 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Lucky8 Llc. - Take the road less traveled...
and don't look back, by the time you buy new ends and get the old ones out it will be worth it. Hardest part will be getting the link that connects at the steering box off, it will be reused.
measure old bars and get new ones as close as possible, then throw a tape measure on to check alignment.
~ Semper Fidelis ~
Old June 16th, 2015, 08:34 AM
ezzzzzzz
Mark Garrenton
^ replace all.
Old June 16th, 2015, 09:20 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Check Rockware for his HD version. I was very pleased.
Old June 16th, 2015, 10:14 AM
huibae's Avatar
huibae
Harold Lee
Jon Snow Badge 1122
Originally Posted by speedpin View Post
Lucky8 Llc. - Take the road less traveled... and don't look back, by the time you buy new ends and get the old ones out it will be worth it. Hardest part will be getting the link that connects at the steering box off, it will be reused. measure old bars and get new ones as close as possible, then throw a tape measure on to check alignment.
Great. Thanks.
Does the lucky 8 set have everything I need? There doesn't seem to be an arm for the steering dampener in the picture.
Old June 16th, 2015, 10:45 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
The damper connects to the reused piece mentioned at the steering box arm. Yes the kit is everything you need.
~ Semper Fidelis ~
Old June 18th, 2015, 01:15 PM
huibae's Avatar
huibae
Harold Lee
Jon Snow Badge 1122
Went back underneath the truck last night. Looks like the back tie rods and track rod tube are fine. But the front tie rod on the passenger side and the ball joint below the dampener are super loose.
Gonna buy the front tie rod and track rod tube to replace.
Question: should I try to rebuild the ball joint below the dampener or replace it all with this unit:
DROP ARM w/BALL JOINT LHD-RANGE ROVER CLASSIC 87-91, DEFENDER, RNS080, QFW000030 - Rovers North - Classic Land Rover Parts
Thanks in advance,
Harold
Old June 18th, 2015, 02:15 PM
Many say count exposed threads on the old before you remove and screw the new ones in the same. I don't buy that school of thought but the eye to eye measurement between the knuckles is a good way to go. Measure before and match that with the replacements.
Old June 18th, 2015, 02:26 PM
tjfslaughter
thomas
Burbon
Make sure you purchase anti seize when you do it.
Old June 18th, 2015, 02:29 PM
ezzzzzzz
Mark Garrenton
Maybe you can get the ends out of a cali truck but not so much a east coast vehicle. I've tried too many times without success. It faster and reasonably cheap to upgrade these parts in one swoop.
Old June 18th, 2015, 03:16 PM
It's easy to get the tie rod ends out. You have to really soak them with heat, MAPP gas or better.
Then drench with PB blaster. Put the thing on an anvil and bang with a BFH on the side of the tube in the section where the tie rod end is, as you roll it around on the anvil. Obviously don't hit it past that point or you will flatten it. Rinse, repeat. It is a relatively thin wall tube AND it is split at one end. Banging it like that will break any rust bond between the male end female threads, Have yet to fail on getting them out since I started doing them that way. Pipe wrench is good for freeing them, once the above steps have been performed and the rust demons exorcised.
Edit, to address responses below...If you are replacing a damaged tie rod or upgrading to a stronger design, yeah, just go with all new stuff. Of course.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 18th, 2015, 03:35 PM
ezzzzzzz
Mark Garrenton
^ too much work (or I'm a lazy f**k).
Old June 18th, 2015, 04:14 PM
tjfslaughter
thomas
Burbon
It was easier to just get the Rockware with new ends when I did mine
Heavy Duty Track Rod Kit with Tie rod ends $250.00 SafariHP The Vendors Loft 0 August 30th, 2012 04:20 PM
Defender 110 Tie Rod Steering rod change tjfslaughter Defender Technical Discussions 23 December 14th, 2011 10:53 AM
1994 D90 Tie rod and steering stablizer jimmybuffett Wanted 4 October 13th, 2011 08:27 PM
Tie Rod/Track Rod joint removal....aarrrrghh DNinety Defender Technical Discussions 5 October 24th, 2010 01:08 PM
Complete set of Defender steering tie rod ends crown14 For Sale - Parts 7 February 5th, 2010 09:45 PM
