Steering pump? - Defender Source
Old October 12th, 2015, 12:10 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Steering pump?
The last several days my power steering has started feeling.... stiff.
It almost feels stiff at different points during a turn; and it doesn't want to self-straighten after making a turn.
Does that make sense?
RRC LWB w/ a 300 Tdi
Rent my
Old October 12th, 2015, 01:05 PM
I would first look at the rest of the steering system. Jack up the front axle and see if it steers easily with the engine off or not. If it is still stiff, then it is not the power steering at fault.
Can be lots of things, but steering shaft u-joints are common.
Old October 12th, 2015, 01:08 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
You know what, now that you say that.....I remember thinking when I was swapping the motors that the steering shaft looked crappy where that rubber dough-nut thing is...
Rent my
Old October 13th, 2015, 08:51 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Jacked up the front end last night.
With both tires off the ground, it has a *notchy* feel as you turn the wheels.
It's got to be the u-joints binding up...
Rent my
Old October 16th, 2015, 08:45 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
update:
Replaced the steering shaft this evening.
Old u-joints were BAD!
Really bad.
The joint closest to the steering column was extremely stiff in both directions and the one near the steering box was stiff in one direction...
New shaft is in and steering is smooth like butter and easy.
Good call, Red90.
Rent my
TD5 Fuel Pump/ pump tomaco1 For Sale - Parts 7 September 20th, 2011 09:13 PM
feed 200tdi lift pump from Facet fuel pump ? kjva Defender Technical Discussions 1 September 7th, 2011 01:55 AM
D90 Power steering PUMP WhiteD90 Wanted 1 February 1st, 2005 12:09 PM
Vendor for Power Steering Pump Pulley wheel ? norros Defender Technical Discussions 0 January 19th, 2005 04:12 PM
3rd - Detroit Locker 4.10, Auto Trans, Steering Box, ABS Pump mudrover For Sale - Parts 2 August 9th, 2004 12:25 PM
