ST Window Top Rehab - Defender Source
Old August 7th, 2011, 02:32 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
ST Window Top Rehab
I am almost finished with my soft top window top project. I completely stripped them down, re-painted them (Portofino Red) and have installed the Garrison Outfitters EPDM window channels http://www.garrisonoutfitters.com/ProductPage1.html
If anyone is interested, I would be glad to share my experience and some tips.
The Garrison kit is very complete and the instructions are pretty good. The key, as I found out, is to really get the channels absolutely clean of debris from age and the residual glue/fibers from the old felt.
ID:	40936   Click image for larger version
Old August 10th, 2011, 06:57 AM
kevkon's Avatar
kevkon
kevin
Found a neat way to resolve the issue of water ingress at the studs. All it requires is a 3/8" x 1/2" grommet.
Old August 10th, 2011, 09:53 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
On my fathers 90 I have never had that problem with water coming down the studs. But on the 90 door tops on my series I have that problem now, before with the british bulldog doortops and factory rubber with no foam bits it never leaked. I think it has something to do with the rubber gasket between the door top and door bottom.
Old August 13th, 2011, 09:45 AM
kevkon's Avatar
kevkon
kevin
I ordered the the replacement gasket, but after comparing them with the original, I decided to re-use the originals. The little foam blocks are what I have found to be insufficient and my grommet fix eliminates the need for them @ the studs.
window
Window seals for Fiberglass Hard Top (wanted) wildenbeast Wanted 1 November 1st, 2005 10:55 AM
FS: NAS Fiberglass Top, NYC area NASD90 For Sale - Parts 1 September 1st, 2004 05:17 PM
Soft Top Side Window Bar boshea Wanted 2 June 18th, 2004 08:14 PM
Best top rear window closure Cyborg Defender Technical Discussions 16 April 27th, 2004 03:40 PM
Window Top Bag Joe P Wanted 4 March 14th, 2004 05:39 PM
