Spring Retainers - Defender Source
Old February 1st, 2015, 02:40 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Spring Retainers
Just wanted to share what I've been using for front lower spring retainers. This would work for rear lower as well.
http://www.ballisticfabrication.com/...er_p_1460.html
These fit a Rover coil(not 110/130) perfectly.
I drilled two holes in mine the same as the spring perch. Slide the retainer into the spring and put the bolts in somewhat loosely. Take weight off the axle(jackstand under frame/bottle jack under axle) and spin the spring by hand until the retainer is "threaded" all the way down. Tighten up the bolts. Done.
spring retainers vs dislocation cones wantone Defender Technical Discussions 10 March 21st, 2012 02:28 PM
WTS: 110 fuel sending unit, Terrafirma spring retainers, Land Rover Gear Sandals mcoleman762 For Sale - Parts 4 October 6th, 2011 09:13 PM
Spring Retainers TexasD-90 Defender Technical Discussions 14 January 14th, 2011 07:28 PM
Rock Ware Rear Spring Retainers Mr_Bodgers For Sale - Parts 8 April 13th, 2009 05:36 AM
Front spring retainers, where? artm Defender Technical Discussions 11 September 17th, 2005 01:12 AM
