Speedometer - Defender Source
Old November 2nd, 2008, 11:40 PM
Alex D90's Avatar
Alex D90
Alexander Lo
1995 D90
Speedometer
1995 D90 with about 82xxx miles. The speedo seems to be reading about 11% fast, and yes I do have the correct rolling diameter tires. I also noticed the needle is very erratic, and shaky at times.
Suggestions? My tire and wheel guy, who is also a mechanic, says that I should lube the cable.
Alex
Old November 3rd, 2008, 01:49 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Lubing the cable should help the erratic needle, but it won't stop the over-reading.
Might pay to check that the correct speedo drive gear is in place in the transfer box (i think it's the blue coloured one you need for 235 or 265 tyres)
speedo
Speedometer not working mgrgpg Defender Technical Discussions 4 June 11th, 2009 07:27 PM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
Milage/ Speedometer calibration? oldscratchggf Defender Technical Discussions 3 January 3rd, 2006 03:59 PM
Correcting speedometer after lift/tires Seriesman Defender Technical Discussions 16 November 24th, 2005 08:37 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
