Soft Top Two Piece Door Fix - Defender Source
Old July 4th, 2015, 06:21 PM
Dogpilot's Avatar
Dogpilot
James Wallace
Defender 90 1997 NAS ST
So one of the things two piece doors do is lean away from the top. So you tend to get gaps around the upper seal and a nice whistling or steady stream of water in the rain. So, earlier I had put some rubber strips to make it lean in a bit. Well worked alright for a season, but the rubber compresses.
So I went and made some tabs from thin sheet aluminum. I bent over about " to make it kind of a tapered shim. I made four, one for each stud. Then I made a strip from ABS plastic sheet about 3/8" this to run between the studs and some bits for outside the studs. Torqued down the nuts and the doors now fit snugly on the top and the top of the door does not wiggle anymore.
Cheap fix, with I suspect 1,000 variations to be found in the wild.
Old July 4th, 2015, 06:37 PM
Of all the things wrong with my truck, I don't think this is one of them
I recall seeing on here once that someone made a clip that hooked on the top window channel and then onto the sun visor to hold the top in at speed - of course you'd have to remember to undo it, but I guess good for long trips.
I like your idea, although I'd just 3D print something like it. If anyone wants to try this let me know and I'll give it a shot. The nice thing is you can trivially make them any thickness and size that way.
Originally Posted by pendy
I'm here for the D's
Old July 4th, 2015, 07:03 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
1,001 I cranked on the door top towards the interior of the truck. Worked well.
Old July 4th, 2015, 07:46 PM
Grover's Avatar
Grover
Very clever...
Old August 12th, 2015, 09:50 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
What would be even better is to have the rubber seal made with this in is.
But good idea none the less.
door, soft top, top
1983 110 two piece middle doors o2batsea Wanted 13 June 4th, 2015 12:53 PM
Genuine 110 Full Rack with Two-Piece Ladder Ash For Sale - Parts 13 October 29th, 2014 07:42 PM
Two piece door top 'fastners' Spook Smaller Projects 15 September 30th, 2014 10:07 PM
Two new things to fix. Raidus Arm Bushing and Parking brake bossman429 Defender Technical Discussions 21 October 2nd, 2012 02:15 PM
2-piece to 1-piece roll-up doors J4hand Defender Technical Discussions 2 March 25th, 2009 09:42 AM
