Soft top to hard to should I - Defender Source
Old January 7th, 2013, 03:54 PM
Arran73's Avatar
Arran73
Arran Thomson
1987 90 soft top
I would like to put a hard top on my 90 for the winters and can get my hands on an original hard top and rear door but coming from the wrangler scene were it's easy to go between the two I'm not sure the same can be said for the land rover. Any thought
Old January 7th, 2013, 04:13 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Will you be transporting passengers in the back? If not, consider sourcing a half cab top. Easier/quicker to put on and cheaper (won't have to source full rear door. Probably much warmer too.
Whatever hard top you do get, I am sure installing and removing components gets quicker every time you do it.
I'm in the process of restoring/repainting one to use but it's still in progress.
Old January 7th, 2013, 04:33 PM
Arran73's Avatar
Arran73
Arran Thomson
1987 90 soft top
Yeah thought of that, would be the easiest solution, any idea is a series half top would fit a 90
Old January 7th, 2013, 04:40 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Can't give you a sure answer on that. I've heard some are compatible (probably depending on year)
I also thought you may consider an even simpler solution. Get a fume curtain. It will isolate the front compartment from the rest of the soft top making it much warmer up front.
Old January 7th, 2013, 05:06 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
That won't work mainly due to the different height of the windshields.
Old January 7th, 2013, 05:07 PM
A 90/110 pick up cab is a one man job to swap and is easier than a wrangler top to do. Any defender/90/110 top or any series pick up can top with a defender top panel will work just fine. A metal 90 or Defender 90 hardtop is not much worse of a swap, but it is heavier and you either need to swap your tailgate out for a full rear door or you need to find a liftgate off a series truck.
On a ROW truck (without a cage) the swap is easy between a softtop to a hardtop and back again. On a NAS truck, it will require some serious work getting all the bolts off the cage and getting that off and dealing with the bits of the cage that stick above the cappings etc..
soft top, top
Looking for "bar" on top of windscreen for soft top chuckc4 For Sale - Parts 2 March 8th, 2006 12:56 PM
Ď95 Beluga Black D-90 Soft Top... obie For Sale - Vehicles 12 January 29th, 2006 09:46 AM
Painted AA Yellow Hard Top For Sale JimC For Sale - Parts 11 November 29th, 2005 11:31 PM
1968 Camaro RS/SS soft top for sale rrubino2 For Sale - Vehicles 0 November 18th, 2005 03:07 PM
Hard Top and Stuff ron For Sale - Parts 22 November 14th, 2004 06:35 PM
