Small or Big Problem - Defender Source
Old July 11th, 2013, 07:47 PM
WD90's Avatar
WD90
Dan
1995 NAS Defender 90
Noticed a rattling noise coming from the bottom of my Defender today... At first I thought it was coming from the exhaust, but it's coming from the front of the transmission... Is it hard to replace transmissions in NAS Defenders? We have several older Discoveries laying around... Could I retrofit one of the automatic transmissions from one of those?
Old July 11th, 2013, 07:56 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Does it sound like a golf ball in a Tin can?
rattling could be so many things, why jump to most expensive so quickly? could be linkages, or cats, or heat shields, loose washers, etc
Mark Kellgren
KM4BOR
Old July 11th, 2013, 08:00 PM
WD90's Avatar
WD90
Dan
Just preparing for the worst... Service guys are going to check it out tomorrow. Just want to know some solutions ahead of time if the transmission is about to explode.
The sound is coming from the exhaust unfortunately... It's at the front of the transmission. Yes, sounds like a golf ball rattling in a can... No change in/out of gear
Old July 11th, 2013, 08:29 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
I am willing to bet it is the catalytic converter, mine is making the same noise, and I need to get it replaced. I am going to buy just the Y section needed and it runs around $400. I don't think the tranny would make that noise unless you were getting some other more serious symptoms.
Take something and bang on your converter under your driver side, might move that loose piece around enough to stop some noise.
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old July 11th, 2013, 08:46 PM
trannies make a knocking, not a rattling sound when going bad.
sounds like you have a classic bad cat. if i were you, I wouldn't tell the mechanic a thing other than you hear rattling. I'm sure he would love to sell you a tranny replacement if you opened the door for him.
Mark Kellgren
KM4BOR
Old July 11th, 2013, 09:10 PM
WD90's Avatar
WD90
Dan
I hope you're right... They're my service guys, so they better be good to me!
Old July 11th, 2013, 09:16 PM
if the cat is bad, you can bang on the cat and hear it rattling inside where the matrix has come apart. You should also be smelling the rotten eggs by now.
Mark Kellgren
KM4BOR
Old July 11th, 2013, 09:36 PM
WD90's Avatar
WD90
Dan
No smell yet, but I'll beat it with a hammer tomorrow and see what happens
Old July 12th, 2013, 09:47 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Bad cats can also make your engine get hotter over time.
Old July 12th, 2013, 10:04 AM
WD90's Avatar
WD90
Dan
The guys are telling me that it's the cats... I have a guy up the road that will straight pipe it for about $50.00...
Old July 12th, 2013, 10:45 AM
Why not get a new y pipe? They don't like running without cats.
Old July 12th, 2013, 10:52 AM
bjf's Avatar
bjf
barry f
94 ST #395
Cut them out and have magnaflows installed.
Old July 12th, 2013, 11:01 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
The 3.9 runs great without cats.
You may not like the extra rumble or hollow tone it produces.
The easy method is to just drop the y-pipe cut open the cats and clean out all the filter/honeycomb material.
You'll probably find yours is alread broken into pieces.
The more involved method is to remove the cats and weld in straight pipe(which cuts down on the resonance).
Determine first if this is the source of your noise.
Rent my
Old July 12th, 2013, 11:37 AM
WD90's Avatar
WD90
Dan
My service manager is 99.9% sure that it's the drivers side cat...
The PO had a Flowmaster muffler installed, and it already has a growl... I'm curious to see how it sounds without the cats. I am worried how the engine will perform without them... guess we'll find out.
Old July 12th, 2013, 11:44 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
A thermal IR gun will confirm the blocked cat in 30 seconds. Measure the inlet and exit temps of both cats to compare.
Old July 12th, 2013, 12:37 PM
Not having those cats via straight piping it can be a problem in some states with emissions inspections (not in NC, but some places).
Mark Kellgren
KM4BOR
Old September 4th, 2013, 10:46 PM
coffee's Avatar
coffee
John Oates
1993 NAS Defender 110 #367/500
I cut out my cats and it runs fine, but you're right...I barely squeaked by inspection this year
Old September 5th, 2013, 08:29 AM
worried how the engine will perform without cats ? The engine will perform much better, its the environment that the cats protect not the truck.
Old September 5th, 2013, 10:20 AM
ezzzzzzz
Mark Garrenton
If you happen to get busted by the inspector then you'll have to replace it properly anyhow. If a state trooper just happens to be around at that time you could be looking at serious $$$ penalties. The EPA and DOT love busting on this stuff. Seriously, it's just an anemic LR 3.9 so gutting the cats isn't going to make huge power gains. You can replace with a new y-pipe which should increase exhaust flow by default. Alternately, you could fit aftermarket small hi-flow cats to decrease backpressure. Fix it right and be done with it.
Fun for the kids, big or small d90-110 Misc. Chit-Chat 0 December 18th, 2008 10:30 AM
steering problem jorge Defender Technical Discussions 3 June 29th, 2005 08:12 AM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
galv. small parts mattdh Defender Technical Discussions 0 November 20th, 2003 08:31 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
