Shovel Mount - Defender Source
Old December 18th, 2012, 10:16 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Shovel Mount
This may be the smallest of small projects, but I'm glad i did it.
I always had my shovel quick-fisted to the inside of my wheel well in the cargo area of the truck. Not a big deal but not the best place for it. Wasted inside space and a pain to get to if I had cases in the back.
So - i made these clamps to go on the side rail of my roof rack. Had some stainless hardward to use. Currently they are drying with a coat of paint....
Pic shows them mounted on a piece of stock thats the same as my roof rack. - I'll only put it on when I plan on going off road/on trips
Very secure - doesn't rattle at all. - makes me feel like I had a productive Tuesday night I think I may try to do something similiar with the Hi-lift, but I'll probably not use quick fists for that.
ID:	62954   Click image for larger version
ID:	62956   Click image for larger version
Old December 18th, 2012, 10:25 PM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
Those things hold up to UV light pretty well?
Old December 18th, 2012, 10:32 PM
A hole needs far less hardware.
Old December 18th, 2012, 10:42 PM
bossman429's Avatar
bossman429
Adrian
1988 90
You mean just drilling into the rack?
Downsides:
  • Fixed position, can't ever move it if I want/need to
  • My rack is galvanized steel. If I drill holes into it, I'll be removing zinc making areas for rust to start... I did end up doing this for my jerry can mounts and afterwards i regretted it...although so far as long as i keep the stainless bolt screwed in tight, it hasn't started to rust yet
  • I'd be stuck inside doing nothing all night.
------ Follow up post added December 18th, 2012 10:42 PM ------
The quick fist? They are a rubber so yes... they are very very strong, durable,and easy to "un-latch" Firetrucks use them a bunch to hold all their tools
Old December 18th, 2012, 10:47 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Yeah, but it would be a lot less fun to work on, wouldn't it?
Old December 18th, 2012, 11:27 PM
Stainless u bolt a plate to the rack and then you can drill that to your hearts content.
Old December 19th, 2012, 11:38 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I think it looks pretty trick Adrian. A shovel and enough time you could dig yourself out of almost any non-wet situation. I'm thinking of moving my Hi-lift outside of the truck so would be interested to see what you build on that project.
mount
Cheap shovel mount. broadstone Smaller Projects 1 December 30th, 2012 03:10 PM
Seat covers and shovel mount ORover Wanted 1 February 6th, 2009 03:41 PM
WIng top shovel mount parts needed Cyborg Wanted 0 March 8th, 2006 11:12 AM
Lap Top Mount Joe P Misc. Chit-Chat 10 March 28th, 2004 04:10 PM
Cubby console mount bd90 Defender Technical Discussions 4 December 4th, 2003 01:05 PM
