Seats - Nothing's Easy - Defender Source
Old July 13th, 2016, 07:36 PM
Those with early trucks who have changed seats with older defender style seat rails -
did you go from this:
to this:
If so, talk to me goose. Did you just drill new holes, tap threads, bolt size, what? For even more fun, this older style rail is screwed into captive nuts on the underside of the seatbox.
So much for a five minute job....
Thanks!
Old July 13th, 2016, 08:45 PM
heh - replying to my own thread
one option is to re-use the older seat base, similar to this AB video (sorry Zack)
i don't know how to embed that thing
Old July 13th, 2016, 08:57 PM
The captives are in a simple bracket held by a rivet. Easily drilled out and dropped.
I like the military way of fixing the seats to the seat box. Use a large washer and a bolt about 3/8 longer than needed to come up through the hole from underneath. Use another washer and nut on the top. This will leave a set of four studs to set the seat onto and then use nylocks to fasten the seats. This set up places the seat rails up slightly off the seat box which helps greatly removing the battery box and tool box lids. If you have cursed the original design trying to get these lids out you know what I mean.
Old July 13th, 2016, 09:45 PM
Thanks Doug - that's a really good idea
Old July 14th, 2016, 12:47 AM
BlackField's Avatar
BlackField
Oscar
D110
Riv nuts
Old July 14th, 2016, 07:52 AM
Originally Posted by BlackField View Post
Riv nuts
Hadn't thought of that - thanks
Old July 14th, 2016, 09:13 AM
Naplm00
Matthew
I was gonna say rivnut too, but I wouldn't trust them in an accident
Old July 14th, 2016, 09:17 AM
I haven't tried a riv-nut just because you can't add a backer so its only a surface mount in thin aluminum. Lean back too much in your seat trying to adjust a kid in their car seat etc...and pull out a front riv-nut
Old July 14th, 2016, 09:41 AM
BlackField's Avatar
BlackField
Oscar
D110
The thread strength on a rivnut for this application would be in the thousands of pounds range. I don't think the rivnut itself will fail. But I can agree that if you do not size the hole (or loosely fix the rivnut) it will allow the material around it to deform and fail pretty easily.
Old July 14th, 2016, 02:13 PM
note to thread:
the new style bolt size is M8 x 25 (FS108251L, superceded by FS108257L), which is also threaded into a riveted captive nut in the workshop manual
OLD STYLE
NEW STYLE
checking to see if i have any M8s and washers lying around...
Old July 14th, 2016, 09:33 PM
so drilling it is, tried to take an easy path of reusing the existing seat rails - no worky
Old July 15th, 2016, 02:11 PM
i am not alone
http://www.defendersource.com/forum/...ats-69270.html
http://www.defendersource.com/forum/...uts-31959.html
Old July 15th, 2016, 10:48 PM
did a quick install using John's method of using existing holes
used the inside ones closest to the console since i don't have a center seat
worked fine except, as Doug said, the seat box covers are now a huge PITA
this is not over
seats
Black Friday Sales? Or nothing too exciting? spammer Misc. Chit-Chat 26 December 1st, 2013 08:32 AM
Intermittant power loss and now nothing Northidaho Defender Technical Discussions 3 June 28th, 2011 11:13 AM
Nothing formal, trying to get Tampa Bay Owners out for some fun.. aslostasyou Misc. Chit-Chat 2 May 7th, 2009 10:31 AM
Hubs- Can nothing be easy with this truck? punter Defender Technical Discussions 29 December 7th, 2006 03:11 PM
Funny read, but nothing to contribute to this board ini88 Misc. Chit-Chat 1 October 25th, 2005 12:04 AM
