Seat ECU repairs for DrDread - Page 2 - Defender Source
Old September 30th, 2015, 07:56 PM
Bring it
Old October 27th, 2015, 01:06 PM
pl626's Avatar
pl626
Peter
1995 Range Rover County SWB
Originally Posted by o2batsea View Post
...Dunno if it would be considered upgrades but two things I did that help is put in a 150 mA battery instead of the 100, and install the new integrated circuits with socket plugs instead of direct to the card...
I don't think you can get the 100s anymore. I've only seen the 150s. I think the sockets should be mandatory in a rebuild, as you won't expose heat to the ICs when soldering.
Originally Posted by drdread View Post
...FYI, I hope you're in the mood for some more love, because I'm referring like 6 guys to you with probably the same problem...
I've been singing your praises as well. I don't have the patience or vision to do trace repair anymore, nor do I enjoy soldering.
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'87 HD FLST w/ '02 Fatboy sheetmetal
'02 Hobie Getaway
Old October 27th, 2015, 01:21 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Bill, you want to buy this one or is it shot?
C'mon, make me an offer....
Rent my
Old October 27th, 2015, 01:25 PM
pl626's Avatar
pl626
Peter
That's not bad. Doesn't look like you have any blistered caps, and your diodes and resistors seem to be in good shape. Just need to inspect the traces under that first IC.
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'02 Hobie Getaway
Old November 21st, 2015, 09:13 AM
ECU from member Huibae before:
And after
After testing today will be going back to its owner.The traces for the battery were gone eaten away. I replaced those, installed a few new capacitors, installed the socket for the IC, new battery and new IC. Cleaned up all the contacts on the relays. Good to go ready for minimum 5 years before it needs a new battery service.
I have two more ECUs in progress. $300 for one and if you send me your old one I credit you $50 so you get a fully functional tested unit for $250.
Old November 21st, 2015, 10:36 AM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
Mine is working like a charm by the way.
Should've sent you the switches too. They were toast but I was able to wd40 and scrape the rust off of them.
Thanks again man.
1994 Silver DEFENDER 90 NAS SW
ecu
2 4.2 ECU's 1 3.9 ECU eliaschristeas For Sale - Parts 3 June 19th, 2013 03:15 PM
Need an ECU... looking for the ECU out of a 95 Disco or equivalent IPSC_GUY Wanted 7 February 16th, 2010 04:36 PM
BesTop Repairs? boshea Wanted 3 January 3rd, 2004 12:17 AM
BesTop Repairs? boshea Defender Technical Discussions 3 December 29th, 2003 10:22 PM
