Saturday's escapades... - Defender Source
Old April 9th, 2014, 08:05 PM
trailer guy's Avatar
trailer guy
Ben Jones
Defender 200tdi 110 Hard Top
Got busy with Lola on Saturday The lucky girl got:
Cam belt and tensioner change (had already done the water pump a few months ago)
Obviously new coolant/antifreeze
Oil and filter change
One new tyre
Topped up diffs
Topped up gearbox
Topped up transfer box
welded the back box up
Greased the props & UJs
Jet washed the chassis in prep for giving her a Waxoyl coating
Should've been pretty quick and easy stuff, but the crankshaft bolt and pulley put up a serious fight! In the end my brother and I had to fabricate tool to hold the pulley still (to stop the engine rotating) and use a 4' long 3/4" breaker bar to undo the bolt! Still, I guess 341Nm, thread lock and several years heat will do that to a bolt!
Well, I was going to post a few pics up for you, but it looks like the iPad and Defender Source don't like each other... I'll stick them on tomorrow, when I'm at the PC
Old April 9th, 2014, 08:24 PM
I was working on a customers 300 tdi to get the timing right with a dial indicator last night and went to turn the engine backwards to get the lift right and the damn crank bolt backed out !
The "rover shop" that had replaced his injection pump hadn't used thread lock or an impact putting the bolt back in. I guess its a good thing they also didn't time it quite right so the error was caught before the crank nose got chewed up.
Old April 10th, 2014, 06:20 AM
trailer guy
Ben Jones
Sounds like your customers' lucky that you at least know what youre doing! That could've ended a lot worse for them...
Here's some pics as promised!
ID:	92791   Click image for larger version
Name:	IMG_7097 - Copy.jpg
ID:	92793   Click image for larger version
ID:	92795   Click image for larger version
Old April 10th, 2014, 02:43 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Real nice. There are so many captions that can go with image 7...
Rausch Creek this Saturday Roverlab Trips, Trails and Events 1 April 23rd, 2008 07:17 PM
Wrenching party in Nova, Saturday April 28th cgalpin Trips, Trails and Events 18 May 24th, 2007 09:10 AM
Crozet Saturday May 13th lobster Trips, Trails and Events 0 May 9th, 2006 02:49 PM
110 At A-Basin Saturday mhansen Misc. Chit-Chat 5 April 23rd, 2004 10:49 PM
Paragon this saturday sflash868 Trips, Trails and Events 0 January 9th, 2004 02:51 AM
