Running Lights Out Left Side Only - Defender Source
Old July 17th, 2014, 09:01 PM
MattGuyver_007's Avatar
MattGuyver_007
Matt VA
1995 D90 SW
I did a quick search prior to posting and couldn't find anything so I figured I'd post to see if anyone out there can help. None of my running lights work along the LEFT side of the vehicle (headlights & signals are OK) are working but the right side is all OK. Yes, the bulbs are all fine. Are the L/R side fused separately? I'm thinking it may be a broken wire somewhere which will be a joy to locate.
Any help / experience with this issue would be appreciated!
Old July 17th, 2014, 09:05 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Happened to me..
it's a 5 amp fuse, can't recall which number, under the fuse box right in front of shifter...
I shorted something and struck me as weird as well, but there you have it!...
Old July 17th, 2014, 10:05 PM
MattGuyver_007
Matt VA
1995 D90 SW
I'll go check right now- thanks for the response!
(Realizing I should have posted this in the technical discussion- feel free to move.)
Old September 9th, 2015, 11:14 AM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
I have the same issue. What symbol represents the parking lights on the fuse panel?
Old September 9th, 2015, 11:31 AM
yes ea side is fused separately. I've offered the advice here dozens of times but the switching to smart fuses where an led lights when you blow a fuse will save hours of frustration. Guess it boils down to whats your time worth ? An assortment pack costs about $22
Old September 9th, 2015, 11:48 AM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
I understand it's fused separately, eventually there will be blade smart fuses installed. But which symbol is associated with the parking lights? The headlights work, so it's not the headlight fuse.
Old September 9th, 2015, 12:45 PM
61rover's Avatar
61rover
John Crouse
Had the same issue but it wasn't the fuse. It was in the chassis harness. Check and see if your left tail light is out too.
ht, lights
Stock LEFT side running board OEM Happyxhour For Sale - Parts 2 June 6th, 2012 08:31 AM
Running Lights / Interior Lights Short Wolf Fabrication Defender Technical Discussions 21 February 17th, 2012 07:27 AM
NEW- KBX Wing-top Louvre for sale (left side only).... Worldrover1 For Sale - Parts 2 June 21st, 2011 08:52 AM
Left brake lights work....the right and door brake lights won't? beko35 Defender Technical Discussions 4 June 27th, 2009 02:12 PM
Left rear brake Light Out, and I mean Out! RickM Defender Technical Discussions 6 December 8th, 2004 09:31 PM
