ROW D90 LED Light Replacement - Defender Source
Old May 5th, 2011, 06:00 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Just in case anyone else wants to swap out all of the external lights on their Non-NAS 90 with LEDs, I thought I would share the part numbers I used,
These are all from www.superbrightleds.com.
Turn signals (all 4): 1150-A45-T
Front Markers (2): 1156-CW45-T
Tail / Brake Lights (2): 1157-R45-T
Backup Lamp: 1156-CW45-T
Rear Fog Lamp: 1156-R45-T
Side "repeater" lights (I think this was not factory, mine look like they came from a RRC): WLED-A6
License Plate: BA9s-WHP9
I also needed a LED compatible flasher. I used CF13GL-02.
Everything was plug and play, no wiring mods or other messes.
Old May 9th, 2011, 08:27 AM
achampagne's Avatar
achampagne
Adrian Champagne
06 LR3 HSE
"like"
thanks man.
Old May 9th, 2011, 09:57 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Can you post a picture of the lights (at night or dusk). Looks like a nice upgrade.
Old May 9th, 2011, 11:32 AM
navydevildoc
Neill Thornton
Sure, I can do that tonight. They work well. In fact, the front marker lights are kind of too bright.
Old May 9th, 2011, 12:24 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
The 45 LED Tower Bulb is significantly brighter than stock.
There's no such thing as too bright
This has been discussed at length here:
http://www.defendersource.com/forum/...eferrerid=4450
Old May 22nd, 2011, 09:08 PM
Neill:
Post some pics if you can...also, what did the entire lot of LEDs run you cost-wise to do your truck?
Old May 22nd, 2011, 11:11 PM
navydevildoc
Neill Thornton
Doh! Completely forgot about this. I will go do it right now.
------ Follow up post added May 22nd, 2011 08:31 PM ------
OK, here we go... I did the best I could with the pictures. It's very late twilight when I took these.
Here is the front, with headlights on to compare. The front LEDs are ridiculously bright.
http://www.lrcsd.com/neillt/d90-led/DSC_0240.JPG
Here is the back, with just running lights. I have LEDs in the license plate lamp as well.
http://www.lrcsd.com/neillt/d90-led/DSC_0241.JPG
Here is the back again with the brakes on:
http://www.lrcsd.com/neillt/d90-led/DSC_0242.JPG
Back again with the turn signal lit:
http://www.lrcsd.com/neillt/d90-led/DSC_0243.JPG
With the reverse lamp:
http://www.lrcsd.com/neillt/d90-led/DSC_0245.JPG
If there is any other shots you want let me know.....
Old May 23rd, 2011, 09:19 AM
tjfslaughter
thomas
Burbon
very nice.
Old September 23rd, 2011, 11:25 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
I just did the same conversion and I have to say I thought except for the marker lights, the OEM bulbs were "brighter".
I don't know if it was the effect of the lens or what. The LED's definitely had a more "direct" light in addition to side pattern but for some reason the filament bulbs "glowed" more.
Has anyone else done the conversion?
Old September 24th, 2011, 10:16 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
It doesn't sound like you got the 45 LED tower bulbs because they are noticeably brighter.
I have done all exterior lights except headlights, all dash lights (with new VDO gauges) and interior dome lights and I am very happy.
Old September 25th, 2011, 11:26 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
The 45 LED is exactly the one I have, same exact part numbers.
I was surprised too!!!
Out of the lens they are crazy bright........but in the lens the regular bulb seems to "glow" more, ie throw the light. The LED seems to throw more directionally.
I can take a picture with one side done in LED and the other regular and you can tell me......but it seems subjective, but it should be I guess.
Old September 25th, 2011, 11:53 PM
navydevildoc
Neill Thornton
Hmm. Mine are crazy bright. My front running lights are brighter than my headlights!
Old September 26th, 2011, 01:08 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Did you buy the colors to match each light? Turn signals need to be orange, not white. Break lights should be red LEDs not white. I tried white behind red/orange and it doesn't work. The LED have to match the color of the lens for all exterior lights. Also, what kind of lenses do you have? Stock?
I recently put Amber 45 tower bulbs in my Arb bumper as well. Love it.
I'll post some pictures when I get a chance.
Old September 26th, 2011, 01:32 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Correct........the bulbs are all "color matched". The lens' are the OEM.
The brakes and turning are 110's but the fog/reverse are similar to NAS.
AGREE.........the running marker lights are very bright (almost like headlights)..........but everything else looks like a "wash" or maybe even slightly worse.
I will post up "comparo" shots side by side, ie 1/2 truck done............I'll let everyone else judge.
JJ
Old September 26th, 2011, 02:45 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Superbrightleds also offers white LEDs that have a warmer white tone with less blue and more yellow. It's still plenty bright but it looks a lot better than the normal riceboy-style white LEDs.
For what it's worth, I could never get LEDs working on my turn signal lamps with either the stock relay or an aftermarket relay. Perhaps adding the resistors inline would fix the problems but I never tried them.
Old November 2nd, 2012, 07:33 PM
egor
kody martin
1986 Land Rover 90
Read this thread and ended up buying the flasher unit that navydevildoc suggested. Ordered it from superbrights and it arrived in 2 days! Just took 5 minutes to swap it.....and it works fantastic.
Kudos to navydevildoc. Now I'm a little less worried about getting pulled over.
I have an 86 ROW with LED replacement bulbs.
Old November 7th, 2012, 09:46 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Next you need a set of these!
Old November 7th, 2012, 11:40 PM
surf110's Avatar
surf110
Ze
130 Project
Headlight looks like trucklite but repeater and park light have no idea. Any info on those?
Old November 8th, 2012, 09:36 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Trucklite, and euro RDX LED's.
Old November 8th, 2012, 09:55 AM
lrnasd90's Avatar
lrnasd90
J. Landers
1983 110 LHD Galvanized Everything
Can you tell me where you got the RDX LED's?
93 NAS D110 #137 Sold
1-94 NAS D90 #702 Sold
2-94 NAS D90s (#1112, #1586)tdi Sold
95 NAS D90 #262 Sold
1-97 NAS D90 #642 Sold
2-97 NAS D90s LE (#82,#222)Sold
110 Crew Cab Td5 Sold
Hybrid Series 3 Sold
3-D1 Sold
1- D2 Sold
4- RRC Sold
83 110 5dr Diesel (current)
97 Disco XD tdi (current)
I can quit at any time I am not an addict!!
90, ac, d90, ht
Hannibal rack for ROW D90 Hardtop brn24whl The Vendors Loft 4 April 29th, 2009 01:17 PM
1997 D90 SW 3rd Brake Light for Sale Viton For Sale - Parts 3 January 27th, 2009 11:37 AM
97 D90 check engine light - on now off? Eric_S Defender Technical Discussions 3 January 28th, 2005 10:17 AM
Instrument light bulb / Sylvania replacement Mark M Defender Technical Discussions 2 November 17th, 2004 04:23 PM
