Roof tent mounts - Defender Source
Old April 6th, 2014, 12:54 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Roof tent mounts
Looking for pics/ suggestions on how to mount roof type tent to crossbars etc. like to mount to cross members on trailer.
Old April 6th, 2014, 12:55 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
This is begging for a picture of the GTT....
------ Follow up post added April 6th, 2014 12:58 PM ------
Landan, that is one nice Bronco. Please share some pics and details.
Old April 6th, 2014, 08:45 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Never gets old.
-Jeff
X10...
Old April 6th, 2014, 08:48 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Priceless.......thanks, I needed a good laugh.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old April 6th, 2014, 09:08 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Attachment 92551
Wow...looks like you could mount a small hotel on that tiny trailer!
What does that thing weigh??
Rent my
Old April 6th, 2014, 11:32 PM
SonnyAK's Avatar
SonnyAK
Sonny
1993 NAS 110
We have ours mounted to a set of Thule bars which attach to the roll bars via the Thule mounts which were originall designed for the Nissan Xterra bars - works awesome and has been bullet proof for us! You could use a similar setup too...They work with round or square tubes since thery're rubber and have a wide range of movement for size...
Old April 6th, 2014, 11:57 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Yea lot closer. Have high mount Yakima's on there now, just wondering if missing pieces or just drill through tent bottom to attach some device that will hold to bars? Tent bottom little flimsy, could screw/bolt plywood to it and then mount brackets?
Sort of what after
Old April 7th, 2014, 01:28 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
I have an ARB tent and it has 2 channels mounted to the bottom of the tent base (floor). That channel is wide enough to hold bolt heads that can slide to different widths. You use 2 bolts and a piece of metal to attach to what ever you want to mount to. I can get a pick of mine in the am if you would like.
On my trailer, US mil, I had Wolf make up a frame like shown in your pic, at a height that I can use the bottom room that comes with the tent.
With this set up I can mount to the disco, 110, trailer, my ranger pick up or just about anything that will hold the weight....except the ground of course.
Rick
95 P38 "Gus" RIP
03 D2 SE "Fred"
Old April 18th, 2014, 08:21 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Finally got around to finishing trailer. Ended up running flat bar across hoops, adding plywood under tent (marine grade) then drilling through to brace. Easy on/off w tent and hoops allows trailer to haul dirt bikes and as it has locking brakes, manual, can dump firewood etc with it.
Trailer weighs just over 1,000 lbs and can be pulled around by hand easy enough w tent loaded in shop. Flipped tongue over so pintle level w truck as trying to keep stock look to it. That's the reason too for not swapping axle.
Had hyd tank mounted below that I removed but saved mounts in hope of finding a spare tire for it. (And likely adding 1/3 again weight)
Total thus far not including tent is just under $1k but hope to find spare so go up accordingly.
Any leads on spare wheel and tire appreciated.
9.00/16. Doesn't have to be Mohawk brand or 12 ply, just same size.
Old April 20th, 2014, 11:29 AM
morerover
Kevin
1993 D110 NAS
Never gets old.
-Jeff
Do you have a view from the opposite side showing the ladder in place?
Old April 20th, 2014, 02:03 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Humm side in pic is ladder side, but have one of ladder mount and rear before adding braces.
The floor on this is close to inch thick with insulation sandwich by aluminum sheets.
110 roof rack compatible with roof top tent Ncrover725 Defender Technical Discussions 2 March 29th, 2014 07:42 PM
Tranny Mounts, 4cyl engine mounts, Tub tomaco1 Wanted 0 December 4th, 2010 12:42 PM
roof rack and a hannibal roof tent on a ST 90? DonFromWhitby Defender Technical Discussions 6 March 17th, 2009 09:02 AM
Roof Top Tent - $600 RedRhinoProducts For Sale - Parts 0 November 2nd, 2004 08:58 AM
Roof top tent for sale in So Cal kellymoe For Sale - Parts 6 January 11th, 2004 11:54 PM
