Roll Cage Top Bar - Defender Source
Old November 5th, 2008, 01:31 AM
Alex D90's Avatar
Alex D90
Alexander Lo
1995 D90
Roll Cage Top Bar
This might not be the correct part of the forum, but I have a LR ? about the roll cage.
I know that Defenders can come in a few different configurations, but on my truck and most of the soft tops I see there is your standard roll cage (FULL) then there is a thin bar that runs across the top of the truck (width) it is very thin relative to the rest of the roll cage and seems to be there only to hold up the soft top. It is the bar that has no padding on it.
Why is it that I have seen pictures of soft top D90s that do not have this bar? Is that possible? Mine looks as if I could remove it if I remove the rivets holding it on. I do not want to remove mine, I am just confused on why it appears that some D90s do not have the bar - trying to see if that is possible.
Old November 5th, 2008, 02:30 AM
specops1526's Avatar
specops1526
Beluga '97 90
That alpine bow pops out of the rollcage. It's a bit tough to get out but it comes out. Don't remove the rivets. Those are holding the metal cylinders that slide into the holes of the rollcage. I use a rubber mallet to pop mine out. Just do it carefully one end at a time and it should pop out. Truck looks much better without it when the top's off. It can also be a bit tough to get back in, just takes some finessing.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
cage
Military roll bar for sale and canvas top k4rovers For Sale - Parts 8 August 25th, 2011 11:47 AM
needed: roll bar parts, tailgate, soft top bstraw Wanted 3 March 21st, 2006 10:01 AM
ST Roll cage and soft top D90user For Sale - Parts 8 February 14th, 2006 01:23 PM
def 90 soft top roll cage jeff0409 Wanted 0 February 10th, 2006 07:22 PM
rear roll cage, rear seat, soft top surfd90 Wanted 0 January 12th, 2005 02:59 PM
