Resurfacing swivel balls - Defender Source
Old April 13th, 2012, 08:48 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
After completing a rebuild of the front end of my '94 D90 I was surprised to find my truck was leaking like a sieve at the swivel balls and after some research, adjustments and testing I decided it was a result of the pitting on the swivel balls. I tried sourcing some replacements but after several failed attempts figured I may as well try to refinish them as I had nothing to lose! The disclaimer to this thread is if you are attempting this I assume you have already checked your bearings are tight, the swivel preload is correct and seals are in good condition...if not, go back and do those first!
Obviously you will need to remove the entire assembly from the truck so plan to have all the required seals for reassembly and I went ahead and changed the bearings in the swivels as I figured it was good insurance since I was already there. First step was a lot of cleaning as the JB Weld does not adhere well to oily surfaces. I used brake cleaner with a wire brush and paper towels as the first step, followed by going over it with a MAPP gas torch followed by a towel cleaning with PRE cleaner from Eastwood and another torch treatment. I read that some folks used their oven at low temp to bake the oil residue off but wifey was not a fan of that idea!
For application, I first tried using a cheap spatula I picked up at the store based on a recommendation of an article I read online but I can tell you that my experience is that while it will conform nicely to the curved surface, it is also not a precision instrument so you will end up with a lot more than you need on there which will equal more sanding. Speaking of sanding, I picked up a semi-flexible hand sander with various grits of paper. I would not recommend using any power tools for this process as it is just not necessary. After applying the JB Weld, I let it cure overnight and then made my first sanding pass with 80 grit...this was a mistake as while the 80 grit made quick work of the excess, it also dug in a little more into the pitted areas than I would have liked so I ended up needing a 2nd coat of JB Weld in some areas. For the second coat I actually used the back of a giant cleaning swab (q-tip) that I had left over from my Harley days (http://www.harley-davidson.com/gma/g...bmLocale=en_CA) and it enabled me to be a little more exact with placement. After letting the second coat cure all day, I sanded again but this time started with 180 grit, then moved to 400 grit and finally wet sanded with 1000 grit.
After completing all the sanding the swivel ball was wiped down with PRE again and then hit with the torch one more time in preparation for a coating of POR-15. I used a foam brush and hung the swivel ball upside down to paint it...follow the directions on the can for coats and cure time between coats. Overall I am very happy with the finished product and after re-assembling everything am happy to report no leaks after several hundred miles of driving. I apologize for the lack of photos after reassembly and while I tried to take a picture of the setting preload, I just ran out of hands!
As a side note, during the process I also took a few extra minutes to cut a notch in the top of the brake mount bracket so I can remove the caliper/hard line without having to disconnect the entire assembly from the flex line.
Name:	Ready to begin.jpg
ID:	50233   Click image for larger version
Name:	Swivel before.jpg
Name:	Swivel before1.jpg
ID:	50235   Click image for larger version
ID:	50237   Click image for larger version
ID:	50239   Click image for larger version
Name:	Brake bracket mod.jpg
Old April 13th, 2012, 11:28 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
Great thread. Thank you!
Old April 13th, 2012, 11:38 AM
Nicely done!
Originally Posted by pendy
I'm here for the D's
Old April 13th, 2012, 12:02 PM
better than new!
Old April 13th, 2012, 12:18 PM
With the POR-15 if you want a super slick and blemish free finish, try this:
Get a cheap plant mist sprayer and put some Xylene in it. As soon as you have the surface painted, lightly mist it with the Xylene. Then, hit the whole thing with a heat gun to set the surface.
Old April 13th, 2012, 01:37 PM
It will be interesting to see how well the POR stays on.
Old April 13th, 2012, 02:30 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I agree but figure it is worth a try! I will try to remember to post long term follow up! has anyone ever powder coated theirs?
Old April 13th, 2012, 02:58 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Had a local guy try powder coating his swivel balls for a series. Did not go so well. Seal made an indentation in the powder finish when sitting. I do not think this will work out very well for you. I do not think the Por-15 will make a long term repair.
The hints about Xylene and heat have me interested though. I have noticed that Por-15 when applied on a heated surface makes a tempered version of itself. Something between powdercoating and ceramic. So I wonder about batsy's advice. Makes me want to give it a try on something.
Applaud you for your efforts though.
legend in my own mind
Old April 13th, 2012, 03:07 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Well, FWIW, someone on the LRO mailing list used Devcon plastic metal with a top coat of blue 2 part epoxy on his swivel balls in '95 and as of last year it's still holding up well.
http://www.fourfold.ca/RoverWeb/lro/.../950713.html#4 - Subject: Swivel Balls
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 13th, 2012, 06:18 PM
Landy_Andy's Avatar
Landy_Andy
Andy
How about using Cerakote firearm coating, is very hard wearing & being oven cured should stand the friction of the wiperseal. As long as your filler material will stand the curing process might make a good alternative to air dry type paint.... worth a try
http://www.cerakoteguncoatings.com/
Old April 14th, 2012, 05:23 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Don't know the temp at which it needs to cure, but the Devon can take some heat. These instructions use oven curing.
http://www.lrfaq.org/Series/Drivetrain.SwivelBalls.html
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 17th, 2012, 07:44 AM
the rover shop
shayne young
I assume you already converted over to swivel hub grease instead of the oil"!!!!
Old April 17th, 2012, 10:01 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
No, actually I did all of this so I could keep running oil! The water holes at our favorite wheeling spot (Rausch Creek) are typically 3-4' deep so I have found it is easier to have the ability to simply drain and refill the oil than to mess with trying to flush out a watery grease mixture
Old April 17th, 2012, 10:36 AM
Bill Larson
Bill Larson
is that a true condition? I never considered that! I just switched to grease and although there isnt much water to run through out here, I will switch back if there is a disadvantage using grease.
Old April 17th, 2012, 10:38 AM
It only matters if you spend a lot of time in deep water. If your seals are in good shape anyway, then stick with grease.
But yes, it's amazing the lengths we'll go to to oil our balls around here.
Old April 17th, 2012, 10:50 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Like Charles said, if your seals are in good condition and the water isn't too deep/frequent then I wouldn't worry too much. That being said, when I opened up the RH side to check the bearings and such there was more water/mud in there than grease! (admittedly, they were long overdue for service but...)
Old April 17th, 2012, 12:20 PM
Bill Larson
Bill Larson
Ok good! sounds like I'll just leave it, and rest easy that my balls will remain well lubed in shallow water! Thanks guys.
Old April 17th, 2012, 01:06 PM
It wouldn't hurt to check them periodically, or after going in water of course.
Old April 17th, 2012, 04:23 PM
Normally good advice to clean and inspect after each use.
Old April 20th, 2012, 06:51 AM
Does this mean our trade is off?
ac
84/85 RHD swivel balls Landy_Andy For Sale - Parts 3 May 26th, 2012 08:42 AM
Replacing bearings, found swivel balls empty Broncoduecer Defender Technical Discussions 30 December 2nd, 2011 12:46 AM
Hard Chromeing swivel balls pendy Series Technical Discussions 4 February 28th, 2011 08:37 PM
re-drilling the swivel balls slorocco Truck Build-up's & Restores 15 November 17th, 2008 10:44 AM
swivel balls what to do when pitted and why are 110 swivels so expensive draaronr Defender Technical Discussions 3 August 29th, 2004 06:35 PM
