Resealed my steering box - Defender Source
Old April 24th, 2016, 06:33 PM
defenderholty's Avatar
defenderholty
Russell
1985 LR Ninety 200tdi
I was pretty tired of constantly explaining why my truck was pissing lucas all over the street and driveways where I parked, so I decided to take a chance on resealing the input and output shaft on my power steering box.
Taking the pitman arm off was the hardest part. But wasn't that bad, use a good puller (they are inexpensive) and an air hammer. The input shaft seals came out pretty easy, but where the output shaft comes out of the box it was warped, so the seals and snap ring were pretty stubborn. Im guessing that the PO hit it with and 8lb sledge and disfigured it trying to reseal it previously. Im guessing by the amount of rust and gunk around 10 years ago.
All in all it was a job worth doing. Im guessing if you don't have to run out to buy tools it would take somewhere in the neighborhood of 4 hours from taking the box off of the truck to putting it back on.
There aren't a lot of discussions about it, but there maybe should be. I was surprised at how easy it was.
If this is interesting to anyone, it cost me around $32 and about 4 hours, and I would be happy to explain how I did it.
Old April 24th, 2016, 06:44 PM
defenderholty
Russell
Oh yeah, Included in the 4 hours was rebuilding the ball joint at the end of the pitman arm.
Old July 5th, 2016, 10:29 PM
gwmckee
George
1994 NAS D90 #1919
Explain away, please. I'm having a heck of a time getting my output shaft back in.
86 Defender 110 Pieces Parts Gas Tank, Clutch Pedal Box, Bench, Steering Box, Etc... 86Defend110 For Sale - Parts 14 January 16th, 2016 02:03 PM
DII RTE HD steering linkages w/ OME Steering damper Jymmiejamz For Sale - Parts 3 May 22nd, 2013 12:03 PM
Steering stabilizer? D90 to d1 steering. Arcadeus Defender Technical Discussions 2 May 18th, 2013 09:53 PM
RRC steering column, or any steering column for that matter... RRCbass Defender Technical Discussions 0 February 26th, 2013 05:44 PM
Quick Steering Fix - play in the steering wheel. bossman429 Defender Technical Discussions 5 February 27th, 2012 08:37 PM
