Replacement for NAS Cardboard passenger kick panel - Defender Source
Old October 22nd, 2014, 12:12 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
I still have the factory passenger side cardboard kick panel for my 1994 NAS D90 but as in all cases it does not stay in place no matter what I do. I was thinking of drilling holes in the top slot it mounts to and put screws through it to hold the top section in place but before doing so was wondering if anyone knows of a quality steel kick panel to cover the electrical instead.
I have seen a few items online at ECR that look nice but can't find anywhere to buy them or anyone that sells these.
Any help would be appreciated.
Old October 22nd, 2014, 12:29 PM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
I just rehabbed both pressed board kick panels on my 90. I used thin (~1/8") wood strip backing to hold the original shape of the panels and refinished them w/ Duplicolor spray truck bed liner.
I glued the strips in place, but also carefully used staples. As best as I cleaned, I was not satisfied with adhesion to the 25 yeas of dust, soot and oil on the backside of the panels.
The panels came out great and the texture of the liner hides the staples somewhat. The liner is adhering very well. This method is certainly not for the rivet counters but this was one of those "hey, that came out pretty good" surprises.
w
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old October 22nd, 2014, 12:33 PM
jefhuf on here (lelofab) makes aluminum kick panels.
dude. jefhuf - lelofab. search here. search here.
Old October 22nd, 2014, 09:59 PM
wmatos1001's Avatar
wmatos1001
William
Do you know how they attach?
Old October 22nd, 2014, 10:01 PM
The factory bulkhead tabs just fold over them, just like they do on the factory cardboard ones. You won't be disappointed in LeloFab's.
Old October 24th, 2014, 12:25 PM
wmatos1001's Avatar
wmatos1001
William
Hmmm that may explain something. What factory bulk head tabs? Mine has none.
Old October 24th, 2014, 12:58 PM
There are little white tabs at the bottom...seen here in the middle of the pic:
Old October 24th, 2014, 01:06 PM
wmatos1001's Avatar
wmatos1001
William
-Jeff
Thank you I need those. Apparently mine have disappeared over the years.
Old October 30th, 2014, 04:48 PM
pitchrollyaw
wayne p
1985 d90 2.5NA
Were these tabs NAS only or later vehicles? Mine has Pozi screws through the footwells and no evidence of any tabs.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old October 30th, 2014, 07:27 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I can't comment on the ROW vs NAS for the clips but can tell you that typically if you do not have them then your footwell was probably repaired at some point. That being said, I have had pretty good success installing these with the top dash clip holding and then I can furnish a rubber strip for the bottom that helps keep it from sliding, especially when you push your floor mat up against it.
Old July 26th, 2015, 08:58 PM
whinsley
Bill Hinsley
94/Defender 90
Any Update?
Looking for an update. Is jefhuf on here (lelofab) still making aluminum kick panels?
ac, nas
Passenger Side Footwell Kick Board bjp For Sale - Parts 17 August 3rd, 2015 11:16 AM
“Kick panels” Cardboard replacement SlickRockFab The Vendors Loft 114 July 27th, 2015 12:54 PM
NAS Style Used Rubber Kick Panel Set SafariHP The Vendors Loft 8 March 16th, 2010 09:17 PM
Cardboard Kick Panels Mark W Wood Wanted 31 June 17th, 2008 05:35 PM
Jump seat cardboard replacement advice GaryBaxter Defender Technical Discussions 5 August 14th, 2007 02:57 PM
