Removal of evil rivets - Defender Source
Old July 14th, 2014, 06:53 PM
molonlabedoc
Vincent
1987 D90
I am looking to remove some safari window covers in order to touch them up a bit. I haven't a clue how to remove them and put them back on. Any suggestions?
Thanks.
ID:	98768   Click image for larger version
ID:	98770   Click image for larger version
Old July 14th, 2014, 07:08 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
I normally drill mine out. Others just shear off the head with a chisel.
MUDSUX
Old July 14th, 2014, 07:13 PM
molonlabedoc
Vincent
1987 D90
Thanks Mud.
Old July 14th, 2014, 07:14 PM
Drill. Much smaller than the head you see.
Old July 14th, 2014, 07:20 PM
cbfritz_03
Carmen
none
I used a metal bit a little larger than the hole in the rivet. Drill it until the flat, top part comes off. Sometimes it will get stuck on the bit itself that's okay, just pull it off with your fingers or pliers. When the top is off it will either come out on it's own or will leave the neck still inside the metal, you can poke that all the way out with a punch, nail or a small screwdriver. You are going to need to get some new rivets and a gun to put them back on.
Old July 14th, 2014, 07:21 PM
Yes, drill out and replace with a rivet gun. Really easy to do. Make sure to take the drilled off heads off the bit with pliars (grab head, reverse drill) or the swarth may scratch the paint.
Old July 14th, 2014, 08:05 PM
molonlabedoc
Vincent
1987 D90
Thanks everyone. I'm on it
Old July 14th, 2014, 10:03 PM
mask the paint with tape around the area where you'll be working to help prevent tiny scratches all over the place as the rivet breaks apart and spins with the drill bit.
Old July 14th, 2014, 10:09 PM
drill bit is too large if the rivet spins
Old July 14th, 2014, 10:13 PM
Is that what I did? I've only had to drill out the rivets in the door tops and just used the recommended size in the instructions. Good to know!
Old July 14th, 2014, 10:17 PM
That or dull. You want to cut the head off, not get enough grab to spin the rivet. Usually downsizing to a smaller sharper bit works the charm.
Old July 14th, 2014, 10:18 PM
chuckc4
chuck b
Registered User
Replacing window felt perhaps?????
Old July 14th, 2014, 10:57 PM
cbfritz_03
Carmen
none
I find a sharp cold chisel is much quicker and safer than a drill.
-Jeff
I used a chisel first whenever I could, but with some I just had to use the drill.
Old July 16th, 2014, 09:08 AM
Gas_Donkey's Avatar
Gas_Donkey
Julian
D110 Series 3 & Santana 2500
Make sure you get yourself a Lazy ting riveter for afterwards. A normal riveter is hard going on your hands! The lazy tong makes short work of riveting.
Gas Donkey Land Rovers Spain
Exporter of 100% original Land Rovers
Search Gas Donkey Land Rover on Facebook
Old July 20th, 2014, 11:59 AM
RBBailey
RBBailey
1965 IIa
I don't think I'd use a chisel up against a painted surface. I use a drill, size it slightly larger than the hole in the middle. Too small, and it will drill through, but not take the rivet out. Too big and you open the hole more than you want. I just took 20 rivets out of the painted body on mine when I pulled the diamond plate off, no problem.
Evil fiber bushing ... any thoughts? JohnBullsBollocks Series Technical Discussions 5 July 1st, 2014 02:03 PM
Quarter Panel Rivets bweaver Defender Technical Discussions 13 December 5th, 2006 03:56 AM
Attempt to rout the evil regimes fails gtg067i Misc. Chit-Chat 3 July 18th, 2005 05:22 PM
Need plastic rivets to hold side step Campbell Wanted 2 March 21st, 2005 04:41 PM
Are Michelin Cross Terrains Evil? JimC Defender Technical Discussions 8 January 23rd, 2004 06:27 PM
