I did this to the 110 months ago, told my friend and he did the same to his 90. I went to tractor supply and got a section of 3/8" rubber mat, had to trim from 48" wide to 36" wide, and i think it was 77" long, fit perfect. It cost me $45 i think, and looks standard. My dad swears it's quieter, I'm sure he is right, I cant really tell. They have varying thickness you can get as well.
Just an FYI for a good quality mat, keeps the loadspace from getting beat up. havent noticed any moisture underneath either, even in the soft top.
Did the same thing in the loadspace and second row of the 110, only I used the 3/4" rubber from TSC that comes in a 4' x 6' sheet (SKU# 221900399). Make sure you get some fresh razor blades!
Stall mats are not a new trick by any stretch, but glad you found one locally. You can also find thick rubber mats made from recycled crumb rubber at Lowe's that are a perfect 3x5 and need no trimming. That's what's in the 2A and it looks great.
Thanks to "LostChord" I did all flooring surfaces, top of seat box and wheel arches - Huge diff in noise. wish I could fix it to the roof. Oh, much easier to cut with a circular and saber saw.
Wonder if there is a material that could be used under the mat to help control the moisture. Under the front mats of my 90 near the bulkhead I spray WD40. Seems to help the moisture evap quickly whenever I pull the mats to air dry.
Heres a picture of the mat in my 90 John was talking about. I love it, 3'X4' fit perfectly. Its a little quieter...but my 2.5NA that is screaming on the highway doesnt exactly help with the noise
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
